Bosch Fuel pump questions?
What is the threads that go into the top of the pump??? This is same pump as what endyn uses???
I am trying to get some fitting but every where i go nobody knows??? It is getting very
that i can not get this thing in my car!!
Its a fitting for a Weber Carb. It's 12mm x 1.5. actually, it's either 1.5 or 1.25. Either way it says Weber Carb on the little earls bag that it comes in. It's like $5. If you still cant find it let me know, I can pick one up at Earls and send it to you.
I am trying to rig this thing up in-tank. i know the fitting you are talking about and if i have to i will use that one but i am going to try something differnet if i can find the fittings.
thanks for the help!
k
k
StupidSlowRSX
10
May 3, 2004 02:34 PM
