All motor Definitions....
Old Jul 3, 2003 | 07:18 AM
Witty's Avatar
Default All motor Definitions....
Can we get a thread going that defines terms used in this forum some people might not understand.
Example:
Shot Peened ( I just looked this up because I didn't know)
Shot peening is a process that involves the bombardment of metal parts by millions of essentially spherical particles for the purpose of totally preventing or greatly retarding the failure of that part.
Benifits
-Fatigue life is enhanced significantly increasing life of the part
-Surface hardness is enhanced
If anyone else has anything they want to contribute please do.
Old Jul 3, 2003 | 07:52 AM
advanracing62's Avatar
Default Re: All motor Definitions.... (Witty)
Look for Rocket on this post!! He'll blast some crazy terms.
Old Jul 3, 2003 | 07:54 AM
realfasthonda's Avatar
Default Re: All motor Definitions.... (advanracing62)
this sounds like a good idea to me... could be very useful to some people
Old Jul 3, 2003 | 02:45 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty &raquo;</TD></TR><TR><TD CLASS="quote">Can we get a thread going that defines terms used in this forum some people might not understand.
Example:
Benifits
High Compression Pistons (noun)
Pistons which exhibit compression levels higher than that of stock. Higher compression usually yields more horsepower in all-motor applications.
Benefits:
More Horsepower!
Cons:
Higher Octane Gas Possibly
DOHC VTEC Sticker (noun) - A sticker/decal that came stock on 1999-2000 Honda Civic Si that enthusiast buys to enhance the appearance of their car.
Benefits:
Makes your car look better.
Cons:
Some ricers actually believe that this all-motor mod adds 10HP to your car.
Modified by cpforyou at 12:04 AM 7/4/2003
Old Jul 3, 2003 | 03:21 PM
Irishweird00's Avatar
Banned
Default Re: All motor Definitions.... (cpforyou)
Displacement.....
More = More Power
Pro's... go faster...
Con's.... Can't rev as high... due to higher stroke to rod ratio... takes more to move all the parts... and unless you have crazy internals... you can't revs as high as smaller displacement motors..
Old Jul 3, 2003 | 03:50 PM
cpforyou's Avatar
Default Re: All motor Definitions.... (Irishweird00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote"> Displacement.....
More = More Power
Con's.... Can't rev as high... due to higher stroke to rod ratio... takes more to move all the parts... and unless you have crazy internals... you can't revs as high as smaller displacement motors..</TD></TR></TABLE>
UPDATE:
Displacement (noun)
The volume taken up by a single stroke of a piston in an engine or pump.
Mathmatical Model
Hypothesis is that more displacement = more torque
Proof: HORSEPOWER = TORQUE * RPM / 5252
Theefore by increasing torque, at any given RPM, the horsepower is also increased.
Methods of Increase Displacement
BORE OUT!
Pros: R/S Ratio stays fairly he same.
Cons: Thinner Walls
LONGER STROKE!
Pros: Walls stay the same size.
Cons: Worser R/S Ratio in general.
Old Jul 3, 2003 | 03:59 PM
Banned
Old Jul 8, 2003 | 03:57 PM
Optiks.'s Avatar
Venturi effect By definition it is a tube with a constricted, throat-like passage that increases the velocity of the air passing through it
-think intake runners
Pros incresed velocity of the air entering the engine
Cons there is a restriction in the intake stream
thats the only thing that popped into my mind
Old Jul 8, 2003 | 05:59 PM
GetawayInMoscow's Avatar
Default Re: All motor Definitions.... (Optiks)
How about:
boring
honing
how compression ratio is calculated
how VTEC works
bore
stroke
I dunno...just examples of things most people dont know
Old Jul 8, 2003 | 06:16 PM
Optiks.'s Avatar
Default Re: All motor Definitions.... (GetawayinMoscow)
boring- increasing the diameters of the cylinders, wider pistons are also needed, and most likely the combustion chambers must be matched also
honing-polishing the cylinder walls
how compression ratio is calculated- there are 2 ways corrected and uncorrected, but i dont feel like explaing
bore-diameter of the cylinder
stroke- distance from top dead centre to bottom dead centre
Old Jul 8, 2003 | 06:19 PM
Optiks.'s Avatar
how vtec works http://auto.howstuffworks.com/....html
.ti s'taht .rolyaT
Acura TSX
16
May 5, 2007 06:28 PM
zach1288
Apr 6, 2007 11:59 AM
1badda
Dec 22, 2005 11:22 AM
SignNameHere
Aug 10, 2003 11:15 AM
tpr
Apr 25, 2003 06:45 AM
