Crank pulley key way is damaged
Old Jul 3, 2003 | 05:15 AM
BeerMan's Avatar
Default Crank pulley key way is damaged
The key way for the crank pulley has a fairly large nick on one side. The shop says they can probably tig weld it and machine it down as a fix. Unfortunately, the guy said he's never done this before, but he thinks it should work no problem.
Anyone ever have a problem like this? What did you do?
Obviously I am trying to avoid buying another crank.
Old Jul 3, 2003 | 07:19 AM
salt's Avatar
Default Re: Crank pulley key way is damaged (BeerMan)
If you've seen his work and he is a skilled craftsman, I think it would be fine. Especially if one side on the keyway is fine.
Old Jul 3, 2003 | 07:47 AM
BeerMan's Avatar
Default Re: Crank pulley key way is damaged (salt)
Thanks for the reply.
Well, this is the first time I've worked with him, but he has a good rep and seems like an honest guy. He also said that if he thought the fix wouldn't work he would tell me to get a new crank.
Its just that he said he's never had to do something like this; he said that "we are on uncharted waters". Hence, he is having another shop do the repair.
Anyone else have any thoughts, suggestions, experience with this sort of thing?
Old Jul 3, 2003 | 10:24 AM
Swift's Avatar
I had to have the same thing done to my old nissan truck. It lasted about a week, then the pulley tore off while I was doing 70 on the highway. Ended up having to put new crank in. I just hope your guy is better than mine was, of course anybody should be.
Old Jul 3, 2003 | 10:25 AM
BeerMan's Avatar
Default Re: Crank pulley key way is damaged (Swift)
hmm...that isn't encouraging
anyone have happy news for me?
Old Jul 3, 2003 | 11:19 AM
altoid's Avatar
i've got a key way chillin, want me to mail it to you? of course it is from a d series i dunno what you've got
Old Jul 3, 2003 | 11:30 AM
Swift's Avatar
Dont get me wrong. Considering time and money, I say get the guy to weld it. If it holds more power to you. I am just saying I had a bad experience. I want trying to deter you in anyway. $hit happens sometimes, and it just happened to me that itme.
Old Jul 3, 2003 | 02:43 PM
7PSI CRX's Avatar
The crank has to be removed one way or the other.
Replace it with another one.
Old Sep 27, 2004 | 11:51 AM
gomer124's Avatar
Default Re: Crank pulley key way is damaged (7PSI CRX)
is it still holding?, i just cramed a larger key in mine with a hammer, and that fucked it up.
mouab18c1
Mar 1, 2013 03:15 PM
jdmjakebrehm
Jun 16, 2011 11:21 AM
moeslist
Aug 4, 2008 10:59 PM
grey_ghost
Mar 12, 2008 12:52 PM
Baron55
Jun 12, 2007 05:01 AM
