rear suspension "clicks" when going over bump
Old Jul 3, 2003 | 05:05 AM
Thirty-Nine's Avatar
Default rear suspension "clicks" when going over bump
When going over bumps, mostly at slow speeds, I can hear my suspension make a clicking sound. I thought maybe the stock shocks were blown but two weeks ago I replaced the stock shock with Tokico blues and the clicking didn't go away. Each side does it – if I go into a driveway at an angle, for instance, I can hear each side click. Any guesses as to what it could be?
Old Jul 3, 2003 | 05:47 AM
nemesismachine's Avatar
Default Re: rear suspension "clicks" when going over bump (Sushiboy)
did you check the upper and lower shock bolts? the one on the bottom and the 2 in the trunk? (per side)
Old Jul 3, 2003 | 06:00 AM
STIBungy's Avatar
What springs? Do the rear springs have dead coils? If so, do you have those plastic insulators between the dead coils?
Old Jul 3, 2003 | 06:03 AM
civic.com.hk's Avatar
maybe ur springs are not seating properly.
Old Jul 3, 2003 | 06:11 AM
Grocery Getter's Avatar
do you have front and rear sway bars?
check for broken end links front and rear.
-tim
Old Jul 3, 2003 | 07:45 AM
Default Re: rear suspension "clicks" when going over bump (Grocery Getter)
I've got H&R Sport springs. The bolts all seem tight (i'll double check them) and I don't have a rear sway bar.
Old Jul 3, 2003 | 08:07 AM
976's Avatar
976
New User
The clicking is a washer on the strut being slapped, just like your sister last night. Sorry, just joking.
I would try to tighten the strust that is clicking...
Old Jul 3, 2003 | 09:00 AM
Default Re: rear suspension "clicks" when going over bump (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">The clicking is a washer on the strut being slapped, just like your sister last night. Sorry, just joking.
I would try to tighten the strust that is clicking... </TD></TR></TABLE>
Well, I tightend you mom's struts last night … er … something.
Yeah, I'll take a look at that.
Old Jul 3, 2003 | 09:03 AM
Neptune's Avatar
Same thing happens when i take turns slowly. i thought it was all the ruckus in my trunk till I cleaned my car and it still does it.
Old Jul 3, 2003 | 09:53 AM
Default Re: rear suspension "clicks" when going over bump (Neptune)
That's ecactly what I thought, too – too much "junk in the trunk." Holla! Then I realized I didn't have my tools in there anymore.
Old Jul 7, 2003 | 03:02 PM
Neptune's Avatar
Anyone got any pics or a detailed description of what you are talking about. I have stock everything, and I don't know crap about suspension. Thanks
Old Jul 7, 2003 | 03:07 PM
KRiS1's Avatar
Could be the rear trailing arm bushings. I think honda even put out a TSB on it.
Old Jul 7, 2003 | 06:37 PM
Default Re: rear suspension "clicks" when going over bump (POS Hatchback)
i'd be interested in more info on that. Even if I just crawl over a bump, it clicks - I'd think I'd have to be going faster for the sister-slapping washer noise.
Old Jul 8, 2003 | 07:19 AM
Neptune's Avatar
When you lift your car up, like jack up the back end does it make this weird cliking noise? Mine does, same whenever I take a turn at under 10 MPH.
Old Jul 8, 2003 | 07:22 AM
Damon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptune &raquo;</TD></TR><TR><TD CLASS="quote">When you lift your car up, like jack up the back end does it make this weird cliking noise? Mine does, same whenever I take a turn at under 10 MPH.</TD></TR></TABLE>your noise sounds diffrent than theirs..your sounds like a leaking damper.
Old Jul 8, 2003 | 07:23 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: rear suspension "clicks" when going over bump (Damon)
Sounds to me like they arent set in there right....
Old Jul 8, 2003 | 07:26 AM
Neptune's Avatar
I am suspension stupid. Leaking damper? Cause the nosie he describes as clicking or bumping noise is the same noise I get when I take a turn or go over a small speed bump. When lifting the car up, I get a similer set of bumps and clicks too. Do you think it is 2 different problems? What should I look for to see if everyhting is working? Thanks for your help
Old Jul 8, 2003 | 08:11 AM
SOHC_MShue's Avatar
i have a stock suspension and i think mine does this too. Or something similar too it. Not really a clicking noise...well maybe it is..i can't really descripe it. I think it usually happens when i'm making a faster turn though. Or i go down a dip or something kinda fast.
Bangers
Nov 23, 2009 04:32 AM
xTimmyx
Apr 21, 2008 11:57 AM
EP_three
Jul 3, 2007 05:15 PM
OpTiX619
19
Jan 9, 2004 04:24 PM
kek-san
Jan 2, 2003 09:17 PM
