b18a vs b18b
the b18a in most cases will be cheaper due to its age so its a good bet for a rebuild. the newer b18b has a better flowing head although it is nothing very special. the 2 will also differ in terms of OBD.
try searching. good luck
i currently have a 93 ls/vtec with a b18a bottom end and i was considering buying a block but its a b18b....
so having a difference in the ODB would mean an adapter for my current ecu correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 »</TD></TR><TR><TD CLASS="quote">so having a difference in the ODB would mean an adapter for my current ecu correct?</TD></TR></TABLE>
no, you can use both a b18a or b18b, it will require no difference in electronics
95lsteg
Dec 3, 2003 04:10 PM
