shifted at 8K and bent valves??
Old Jul 1, 2003 | 10:27 PM
JDM_ITR's Avatar
Default shifted at 8K and bent valves??
i posted in the all motor forum, but i also wanted to know what you guys thought...
while waiting for a pm from another member on the board, i wanted to see what you guys thought.
I got bored the other night and did ONE run pretty hard, always making sure i shifted at 8K. Ran fine right after that for the rest of the night, but the next day, i had all the signs of bent valves ...and i dont get it, i always shift at 8K.
setup:
lsvtec, ctr pistons, stock 99 b16head, chipped p28
Car sputters (with barely any power) and gets worse the longer i drive. car sputters in every gear up to around 3k most of the time, some times higher. and every now and, it will back fire.
inconsistant idle...below 1K most of the time, feels like it about to die at red lights.
i was about to try different sparkplugs when i noticed that my spark plug wires were wet. it smelled like gas. only the right sparkplug wires were wet. When i took out the right 2 spark plugs, they were wet also, smelled like gas. the other 2 plugs were dry.
I know that i should do a leak down and a compression test, check cap and rotor, and change out the spark plugs.
so what do you guys think?
thanks guys.
Old Jul 1, 2003 | 10:47 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: shifted at 8K and bent valves?? (JDM_ITR)
my cousin missed a shift on my car last year. The idle was messed up and it backfired as well. The signs point towards a bent valve. You said the car was running right but the day after it started showing the signs. Checking the plugs and a compression test is the right thing to do. I think you should check the results first and post up to see what kinda problems it can lead to. Good luck.
Old Jul 1, 2003 | 11:45 PM
d8168055's Avatar
Default Re: shifted at 8K and bent valves?? (Nvious R)
throwing any codes?
Old Jul 2, 2003 | 07:33 AM
ScaleExtric's Avatar
Duy, Pm me..I thought your car is out of commision..this whole time..I dont get it.
Old Jul 2, 2003 | 09:57 AM
JL 74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">my cousin missed a shift on my car last year. .</TD></TR></TABLE>
I still don't understand how people misshift.
Old Jul 2, 2003 | 10:32 AM
Chris N's Avatar
Default Re: shifted at 8K and bent valves?? (jl74)
Cunningham has done it, Kleinubing has done it, F1 drivers have done it at some point in their carreer, sackdz has done it , it's not uncommon. It's not that hard either, especially if you are on a track.
Old Jul 2, 2003 | 01:50 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jl74 &raquo;</TD></TR><TR><TD CLASS="quote">
I still don't understand how people misshift. </TD></TR></TABLE>
Very easy
Old Jul 2, 2003 | 01:57 PM
TypeR 01 886's Avatar
Default Re: shifted at 8K and bent valves?? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
Very easy </TD></TR></TABLE>
You are in 3rd gear all the way to redline
in a haze of adrenaile and excitement you shift really fast to 4rth
drop the clutch..... vroooom all the way to 10k rpms, oops (must have been second)
Old Jul 2, 2003 | 02:09 PM
JL 74's Avatar
Default Re: shifted at 8K and bent valves?? (TypeR 01 886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">
This what happens when you try to "guide" your shifts. Most common is the 5th to 4th (2nd OUCH) downshift. It is just a matter of pulling the lever down without "guiding" and it will go to 4th no problem.
Old Jul 2, 2003 | 02:18 PM
sleeprhatch's Avatar
how about reving up to 8k in third and go to shift in 4th and vroom never went into gear!
Old Jul 2, 2003 | 02:31 PM
JL 74's Avatar
Default Re: shifted at 8K and bent valves?? (sleeprhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeprhatch &raquo;</TD></TR><TR><TD CLASS="quote">how about reving up to 8k in third and go to shift in 4th and vroom never went into gear!</TD></TR></TABLE>
I only do that maybe 1-2 times a week and it goes into gear to me. Maybe because is not an R but I've driven an R so hmmmm.
When I am on top of 3rd, and shift to 4th, I just pull the lever down. Nothing to it. I won't try to get creative and won't nudge it neither left nor right. Just simply pull it down.
Old Jul 2, 2003 | 02:36 PM
CPR's Avatar
CPR
Did that at the ITR Expo after passing someone.
But to keep this topic on track, here's a simple question. Are you sure all components of your engine setup are able to handle 8k rpm?
Old Jul 2, 2003 | 06:30 PM
len's Avatar
len
About a couple weeks ago, I went down to the dragstrip. I was fooling around and not paying attention to my driving and I mis-shifted. I went to 2nd instead of 4th from 3rd gear. My car instantly revved to 12,000 RPMs. Sounded cool. No check engine light, nothing. Still managed to pull a 14.551 on a bone stock motor. Anyways, my stunna buddy said, "hey if the CEL ain't on, run it again..."
I look at him with a wild stare. Then I said, "ok."
I went back down the track and ran a 15.3. LoL
Anyhow, I decided to call it quits. I drove home and hit VTEC a couple times. When I got closer, my CEL came on. The car idles funny and felt like it was gonna die. I did a compression test and came up with a 220, 100, 205, 160 across the board. Oooops...I think I fucked something up.
Took it to the dealership. They open it up and did leak down test and found out I had stretched valves. Beats the hell out of me? I got new valves under warranty.
Old Jul 2, 2003 | 08:20 PM
Nvious R's Avatar
Well, i think everyone was asking that.
Old Jul 2, 2003 | 09:14 PM
gary201147's Avatar
I dont exactly understand how you can bend valves when shifting up because the rev limiter will always prevent you from over revving on the upshift. but a leakdown test would be a good idea
Old Jul 3, 2003 | 03:32 AM
yobtah's Avatar
Default Re: shifted at 8K and bent valves?? (gary201147)
No... it won't. The stock rev limiter is a fuel cutoff. If you're driving in gear, and reach redline, the limiter simply stops the fuel flow. If you miss a downshift (something like 5th to 2nd), the rev limiter can do nothing to prevent the mechanical problem of the engine spinning faster. Basically, the car's moving, and the wheels are turning. The wheels are connected to gears in the transmission... which are connected to the flywheel and engine when the clutch is engaged. The engine is forced to spin by the moving car and gear ratio.
Old Jul 3, 2003 | 09:20 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gary201147 &raquo;</TD></TR><TR><TD CLASS="quote">I dont exactly understand how you can bend valves when shifting up because the rev limiter will always prevent you from over revving on the upshift </TD></TR></TABLE>
it's the fact that they actually shifted down instead of up.. ie 3-&gt;4 became 3-&gt;2
bbqman
Nov 14, 2008 03:33 PM
Insomniac_racer
Jun 11, 2007 08:18 PM
dynamitezz
Oct 28, 2006 08:07 PM
USDM 4G VTEC
Jan 7, 2004 05:02 AM
JDM_ITR
Jul 2, 2003 08:16 AM
