threw a code #9 (cyinder sensor)..please help
Old Jul 1, 2003 | 06:55 PM
dreweg's Avatar
Default threw a code #9 (cyinder sensor)..please help
Well i have a 98 b18c1 in my 92 cx. It threw the #9 code and idles like ***....but it also threw a 41 but that's the 02 sensor so i can fix that easy. Anyway where is the cylinder sensor located???? None of my friends nor I know where it is. Is it in the distributer? I've read posts saying that it was and that i would have to replace the distributer. Any help is appreciated. Thanks guys!
Andrew
Old Jul 1, 2003 | 06:56 PM
poison's Avatar
Default Re: threw a code #9 (cyinder sensor)..please help (dreweg)
Yes it's located in the distributor.
What engine harness did you use?
Old Jul 1, 2003 | 07:08 PM
dreweg's Avatar
Default Re: threw a code #9 (poison)
Obd1 harness and ecu..both from GSR...i also have a distribter i bought from a friend with an obd1 b16.
Drew
Old Jul 1, 2003 | 07:55 PM
dreweg's Avatar
Midnight bizzle my fellow honda-techizzles
Old Jul 2, 2003 | 12:17 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: threw a code #9 (dreweg)
BiZuMp cuz i want to get this done as much as he does...lol
Sean
Old Jul 2, 2003 | 04:02 PM
dreweg's Avatar
Default Re: threw a code #9 (sCeRaXn)
Ok i tried to fix the o2 sensor and well we've pretty much wired it everyway that you can and it still throws the 41 and a 9. It's a brand new o2 sensor. It's a bosch i believe. Do any of you know what the hell is goin on? Thanks
Andrew
Old Jul 2, 2003 | 05:15 PM
dreweg's Avatar
Bump because i really need my car for work
Old Jul 2, 2003 | 11:46 PM
salbaje's Avatar
try finding a friend to lend you a dist to see if the problem disappears. as for the o2 try using oem and plug it in.
Old Jul 3, 2003 | 01:47 PM
sCeRaXn's Avatar
Default Re: threw a code #9 (salbaje)
Hi this is drew on my friends name. I would use the OEM that i had but it is 1 wire and the one i need is 4. But i think im going to use my friends dizzy and 02 sensor to see if the problem dissapears. I just bought that damn sensor at autozone about 2 weeks ago....im gonna be pissed if it's bad. That's like 60 bucks down the drain
BeavisB16
Apr 29, 2005 03:57 PM
dreweg
Jul 6, 2003 01:52 PM
dreweg
Jul 5, 2003 08:39 PM
dreweg
Jul 5, 2003 08:33 PM
dreweg
Jul 2, 2003 05:11 PM
