head swap question
Old Jul 1, 2003 | 03:48 PM
dsadas89das78934's Avatar
Default head swap question
just hoping that i can get some second opinions from ya'll on this site. I have a d16y7 and I'm installing PM6 pistons along with a y8 head and maybe a cam down the road. now here are my questions: 1) should i use my stock ecu but with a VAFC to control vtec engagement or use a y8 ecu and have to rewire everything (difficulty level of that?). 2) do you think there will be any piston-to-valve clearance issues with this piston/head combination? and finally, 3) in addition to new rod bearings and rings and head gasket, what else will i need to complete the swap of the head and pistons? sorry for the long post, but thank you for any help.
also, i have heard something about having to remove an oil control jet on the back of my block for the oil pressure to be correct, know anything about this?
Old Jul 1, 2003 | 04:52 PM
turbotime's Avatar
umm i can help you with some things, for the swap you will need a whole y8 top end including im, and tb. I dont know about the valve piston clearance. As for the ECU I converted to obd1 p28, I wouldnt get the y8 ecu becuase that is a p2p and it sucks for tuning. I heard something about the oil control jet too, but i didnt take it out when i did my swap, thats probalby why it is running to well right now :-P. Anyway, hope some of this helps.
Old Jul 1, 2003 | 06:02 PM
EVIL Hx Coupe's Avatar
Default Re: (turbotime)
Like turbotime said, get a OBD1 conversion harness and a P28... It the best way to go...
Sixx23
May 21, 2015 04:19 PM
pnwjdm
27
Feb 17, 2014 01:31 PM
HondaHemi
10
Feb 8, 2006 01:02 AM
honcrx91si
May 5, 2004 06:13 PM
4g4me
Apr 28, 2003 09:32 PM
