When you installed the alarm in your ef...
Old Jul 1, 2003 | 02:50 PM
Just Checking In's Avatar
Default When you installed the alarm in your ef...
Where and what color was the negative door trigger and the hatch pin. I have a chart that says the door is a (GREEN/red) and the hatch is a (GREEN/black) i have located both of them...(two of the same green/red for the door as a matter of fact) and tested all three with my ohmeter. All 3 show no change from +12v to ground when the doors or hatch is opened.
Any ideas if Ive got the wrong wires? All three that I'm looking at are in the main column harness.
Edit: The supposed (GREEN/red) door wire shows 7.28 volts when door is closed, and 7.26 when open, tested 5 times to make sure its not just error. Whats that about?
Modified by Just Checking In at 4:05 PM 7/1/2003
Modified by Just Checking In at 4:15 PM 7/1/2003
Old Jul 1, 2003 | 04:30 PM
Default Re: When you installed the alarm in your ef... (Just Checking In)
hmm
Old Jul 1, 2003 | 05:08 PM
ghettocrxsi's Avatar
http://members.tripod.com/~dia....html check that out
Old Jul 1, 2003 | 06:08 PM
Default Re: When you installed the alarm in your ef... (ghettocrxsi)
Ok this sounds dumb but, they say its located at the kick panel. well the crx drivers side doesn't really have a kick panel, its pretty much all door untill it ends and the clutch foot rest is stationed. Where the **** is this Magic green/red wire located other then the steering column harness where ive already found two of the exact same green/red, that didn't change volts when the door was opened.
Old Jul 1, 2003 | 11:36 PM
The hatch pin you can use the dummy light from your guage cluster. Just take your cluster out and tracy along the back of the cluster to the harness plugs.
The door pin you can find by taking off the black sliding bar in your door way. Take a look there. I need to remember my alarm install on my crx and I will help u out more
Old Jul 2, 2003 | 11:54 AM
Thanks.
Old Jul 2, 2003 | 10:06 PM
hmmm i still don't see it, anyone remember where they wired the door trigger at?
Old Jul 2, 2003 | 10:50 PM
PhatHatch89's Avatar
It is in the wire loom running along the the bottom of the door jam. You can find it on either side of the car. If you have any more questions just pm me. I can answer just about any alarm question Thats what I do at circuit city.
teamworxek9
Audio / Security / Video
Mar 2, 2009 10:31 AM
EJ8 GSR-T
11
Apr 29, 2007 03:35 PM
408wdy
Dec 15, 2006 09:49 PM
MilanoRex
13
May 22, 2002 01:22 PM
