F22A1 to F22A6 changes
Old Jul 1, 2003 | 12:21 PM
StimpyBoy's Avatar
Default F22A1 to F22A6 changes
I know this must have been answered in some form over multiple posts, but I couldn't think of the right words for a search I guess.
Basically, I'm going to a junker this Thursday and I'd love to do a cheap F22A6 conversion if I find an EX-R in good shape (I'm mainly going for interior parts otherwise). So, I'm trying to make a list of what parts I'll need.
For sure:
Intake Manifold/Plenum/Throttle body (probably not the throttle body, but meh)
Exhaust header + downpipe
EX-R ECU (Can anyone tell me if I must get an EX-R manual ECU? Given I have a manual LX, I'm guessing I can't use the EX-R auto ECU)
Things I'm not positive about:
I think at some point someone confirmed the camshafts are different by looking at Honda Automotive Parts. This is one day where I wish I had a Helms.
I think that's it, I remembered someone saying the bottom internals are the same and such. Can anyone give me a helpful nudge here?
Old Jul 1, 2003 | 12:46 PM
allaboutaccordz's Avatar
Default Re: F22A1 to F22A6 changes (StimpyBoy)
you dont need the EXR ecu, you just have to plug the IAB valve (second set of intake runners) up to the back of the manifold via a vacuum line. this will open the valve at full throttle and leave them closed at idle- much like the EXR ecu, except now they will open before 4000 rpm= more hp at lower rpm.
the camshafts are different between the f22a6 and the f22a1, but the difference in lift/duration isnt enough to put the time into...unless you have the time to spend that is.
i have done this conversion so i can answer any questions you may have.
you will also need a four prong O2 extension cord (from the dealership) due to the relocation of the O2 sensor (it is on the downpipe on the f22a6 rather than the manifold)
Old Jul 1, 2003 | 12:58 PM
StimpyBoy's Avatar
Default Re: F22A1 to F22A6 changes (allaboutaccordz)
Thanks a ton for the kickass help. I may bug you again later if I do find a good EX-R, but that sounds simple enough.
I was hesitant on the camshaft already, and I figured it wouldn't be worth it. This just confirms it.
fryman
10
Mar 24, 2023 01:40 PM
ricerflyby
Apr 7, 2010 10:10 AM
scartail
Sep 17, 2004 02:37 PM
ek_will
Apr 2, 2003 07:08 PM
