B18C1 questions about bore, setup etc...
Old Jul 1, 2003 | 07:10 AM
Nikos's Avatar
Default B18C1 questions about bore, setup etc...
I just got a 96 b18c1 short block that was sitting without a head for a few months and there is major rust in above all pistons. Last night, I took every off the block but the pistons+rods. After taping with hammer a few times, I didn't see any movement on any of them. I know that if I use my 3lb hammer I will eventually get them out but I don't want to do more damage to the cylinders.
Here are my questions: Please take into account that I want to stay N/A and run probably CTR or ITR pistons/rods.
1) What would be the best way to get those pistons out with less damage on the walls? They are stuck with rust.
2) Most likely I assume the block will need to be bored. Can the head remain stock if I bore to a +0.25mm ?
3)While at the machine shop, I have the options of blasting or acid diping the block, turning the crank, balancing flywheel, pstions, rods.... Anything else I should consider?
4) I don't have a head yet. Can you please recommend a setup that would produce same power as a stock b18c5? I think it;s time to start calling the poor man/s type-r, the smart man's type-r
I really would greatly appreciate any feedback.
I just want a good motor with power. No drag, no auto-x, just a good daily driver (94 CX)
THANK YOU!!
Old Jul 1, 2003 | 07:13 AM
.RJ's Avatar
.RJ
Default Re: B18C1 questions about bore, setup etc... (2 B 4GO10)
WD-40 the cylinders
Use a b16 head, same casting as ITR head.
Old Jul 1, 2003 | 07:19 AM
Nikos's Avatar
Default Re: B18C1 questions about bore, setup etc... (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">WD-40 the cylinders
Use a b16 head, same casting as ITR head.</TD></TR></TABLE>
I used major wd-40 for about 6 hours. Those ******* ain't coming out the easy way.
Old Jul 1, 2003 | 08:18 AM
VWeatr's Avatar
Take it to the machine shop. If you marr the cylinders getting pissed off at those pistons, you might have to bore to the point that ITR/ CTR pistons will be too small.
Old Jul 1, 2003 | 11:01 AM
closedhood97's Avatar
CLR, that stuff that they used to advertise on TV. You can get it at Wal-mart in the household cleaning products. I have used it on all kinds of stuff and it works lie crazy. My dad had a Harley rim that had been sitting for 10 years and it made it look new. Just double-check that it is safe for aluminum. I am pretty sure it is.
Old Jul 1, 2003 | 11:19 AM
hybridreams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 B 4GO10 &raquo;</TD></TR><TR><TD CLASS="quote">1) What would be the best way to get those pistons out with less damage on the walls? They are stuck with rust.</TD></TR></TABLE>
Are CTR/ITR pistons what you are rock solid on? If not, you can just hammer the pistons out and bore the cylinders to a bigger bore and get aftermarket pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 B 4GO10 &raquo;</TD></TR><TR><TD CLASS="quote">2) Most likely I assume the block will need to be bored. Can the head remain stock if I bore to a +0.25mm ?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 B 4GO10 &raquo;</TD></TR><TR><TD CLASS="quote">3)While at the machine shop, I have the options of blasting or acid diping the block, turning the crank, balancing flywheel, pstions, rods.... Anything else I should consider?</TD></TR></TABLE>
Installing new bearings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 B 4GO10 &raquo;</TD></TR><TR><TD CLASS="quote">4) I don't have a head yet. Can you please recommend a setup that would produce same power as a stock b18c5? I think it;s time to start calling the poor man/s type-r, the smart man's type-r </TD></TR></TABLE>
B16 or ITR head.
Old Jul 1, 2003 | 05:28 PM
Nikos's Avatar
Default Re: B18C1 questions about bore, setup etc... (hybridreams)
Thanks for taking the time to answer man.
After one whole hour of pounding, I got them out.... Cylinder walls look pretty good.
Tomorrow I am taking it to the machine shop.
Old Jul 2, 2003 | 07:14 AM
Nikos's Avatar
This morning I took the b18c1 block to the machine shop to get measured.
The shop manual states:
Service Limits:81.07mm (3.192in)
Well, my block measures 3.193-3.194
1)I guess I will have to oversize to 81.25mm. Would bigger rings help me retain my current bore?
2) I am thinking about CTR pistons. What rods do you recommend?
3)I have read some good feeback on people using p30(jdmb16) pistons with a b18c1/c5 block and b16/itr head. Compression comes out to be 11.3.
Please let me know, your thoughts on this matter. THANK YOU~!
Note: I don't have a head for the block yet but please assume itr/b16 head with stock internals.
Old Jul 2, 2003 | 07:29 AM
.RJ's Avatar
.RJ
1. use oversize pistons/rings
2. stock rods
3. dont know
THE M4CHIN3
Mar 1, 2014 09:00 AM
totally jay
Jun 21, 2004 09:02 PM
NA-C5
Jan 25, 2004 01:12 PM
Nikos
Jul 2, 2003 08:59 AM
Nikos
Jul 1, 2003 07:18 AM
