OT: That's not a torque damper, this is a torque damper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">jeez... for real! Might as well strap the whole engine down while your at it. </TD></TR></TABLE>
no kidding..
no kidding..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">Isn't it called a Dampner?</TD></TR></TABLE>
i like how people spell things from vernacular
Yes, i do believe it is called a dampener
..doesnt this make you wanna go buy a shock for a off road go kart and slap it on your motor...!?!
look at that supension!
Modified by 10K2HVN at 7:07 AM 7/1/2003
From Mirriam Webster On-Line:
damp·en
Pronunciation: 'dam-p&n
Function: verb
Inflected Form(s): damp·ened; damp·en·ing /'damp-ni[ng], 'dam-p&-/
Date: 1547
transitive senses
1 : to check or diminish the activity or vigor of : DEADEN <the heat dampened our spirits>
2 : to make damp <the shower barely dampened the ground>
damp·er
Pronunciation: 'dam-p&r
Function: noun
Date: 1748
1 : a dulling or deadening influence <put a damper on the celebration>
2 : a device that damps : as a : a valve or plate (as in the flue of a furnace) for regulating the draft b : a small felted block to stop the vibration of a piano string c chiefly British : SHOCK ABSORBER
damp·en
Function: verb
Date: 1547
transitive senses
damp·er
Function: noun
Date: 1748
First, Geratol is right, it's a damper. Well, unless it spews oil all over, then it can be a dampener. Dictionaries are your friend.
Second. I dunno if I'd want to put something like that on the valve cover/topend. I wonder what the longer term effects would be on the headgasket. I know it's not a solid mount, but still...
Warren
Warren
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">First, Geratol is right, it's a damper. Well, unless it spews oil all over, then it can be a dampener. Dictionaries are your friend.
Warren</TD></TR></TABLE>
I'd also be worried about those bolts on the valve cover. It doesn't take more than a few ft-lbs of torque to shear them, so I can imagine excessive engine movement easily shearing all three of them.
Drinker
