t3/t04B trim, 310 injector good for 8psi?????
Old Jun 30, 2003 | 09:12 PM
Fired Honda's Avatar
Default t3/t04B trim, 310 injector good for 8psi?????
Hi just install 310 injector, planning to run 8psi on t3/t04 drag turbo with Apexi SAFC.. Is this a good setup >? or I need to lower the boost???
Old Jun 30, 2003 | 09:26 PM
mamaboy's Avatar
Default Re: t3/t04B trim, 310 injector good for 8psi????? (Fired Honda)
add an fmu 8:1 disc and an Walbro 255lph intank...or DSM450cc's and do the HACK
Old Jun 30, 2003 | 09:31 PM
romeo619romeo's Avatar
Default Re: t3/t04B trim, 310 injector good for 8psi????? (mamaboy)
ya thats fine.. just get a air fuel gauge.. and make sure your in the green at WOT..after that if you got a turbo time by apex you can monitor it with the onboard lambda thats built in it.. i dont think you need a fuel pump for your set up...just get a disk and FPR.. to lean it out a little at idle.. if needed that is
Old Jun 30, 2003 | 09:59 PM
batboyvaj's Avatar
Default Re: t3/t04B trim, 310 injector good for 8psi????? (romeo619romeo)
yea...pm me if you need a 8:1 fmu. i was going to run the same setup.....
Old Jun 30, 2003 | 11:37 PM
InTeGrA B18b1's Avatar
Default Re: t3/t04B trim, 310 injector good for 8psi????? (batboyvaj)
just get 450 injectors 310 is just a waste.
w
May 6, 2005 07:11 PM
ZoNe_HKS
Sep 1, 2003 04:59 PM
Civicdrgrcr
Mar 5, 2003 08:02 PM
JDM EG2
Jan 7, 2003 10:11 AM
ludelvr
Oct 31, 2002 10:05 AM
