b16a1 major problems
Old Jun 30, 2003 | 08:42 PM
Nghtmar911's Avatar
Default b16a1 major problems
Just finished installing a b16a1 into my 89 hf, and the engine runs like total crap. It is throwing code 6 which is engine coolant sensor. Also, my VTEC only kicks in sometimes. Somtimes I can turn it on and it runs fine, but then when I put it in reverse the check engine light comes on and it give me code 6 and start to run like crap again. Any suggestions on what problems it could be before I take it to the shop?
Old Jul 1, 2003 | 12:17 AM
Redline130's Avatar
Default Re: b16a1 major problems (Nghtmar911)
I would double check your wiring and make sure everything is plugged into the right place. Also, make sure all your grounds are nice and secure.
Old Jul 1, 2003 | 12:38 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nghtmar911 &raquo;</TD></TR><TR><TD CLASS="quote"> when I put it in reverse the check engine light comes on and it give me code 6 and start to run like crap again</TD></TR></TABLE>
Cut wire b9 by the ecu, that will fix your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nghtmar911 &raquo;</TD></TR><TR><TD CLASS="quote">Just finished installing a b16a1 into my 89 hf, and the engine runs like total crap. It is throwing code 6 which is engine coolant sensor. Also, my VTEC only kicks in sometimes.</TD></TR></TABLE>
Make sure your wiring is correct and the right sensor is on the right clip, the coolant sensor can be switched with another sensor right by it. So make sure you don't have that switched around.
Old Jul 1, 2003 | 04:57 AM
REDBARON's Avatar
Default Re: b16a1 major problems (90blackcrx)
Mine had the exact same problem. You have to cut B9 at the ecu, and it will solve everything. It's only required if you have an HF though. Make sure to reset your ecu afterwards.
scoobyjr56
Sep 26, 2006 06:47 AM
cogs200
Feb 5, 2006 08:35 AM
surfingsk8r
Jan 27, 2005 06:24 AM
afterburners
Feb 2, 2004 05:18 AM
ErikDaGenErik
Nov 10, 2003 04:57 PM
