Axle clicking on new axles? (with quaife)
Old Jun 30, 2003 | 08:31 PM
b20guy's Avatar
Default Axle clicking on new axles? (with quaife)
When I turn sharply I can hear what sounds to be like axles clicking, like they are shot. But it's very faint, and not a rapid click. I checked under the car, and it seemed that there was something wrong with the driver side axle, felt like there was some play, and the shaft connecting the two boots would slide back and forth. I warrantied this axle out. They are "Cardone" axles from Oreillys. I not sure if that solved the entire problem, as the first circle I made around the parking lot I heard nothing, second I heard it again, but less clicks, same intensity.
What could be causing this? The other side? The quaife? Something else?
96 Civic with B swap and quaife. Helwp.
Old Jul 1, 2003 | 08:45 AM
B16Ej1's Avatar
could be your bearing, my boy just changed his axle, and he still heard clicking come to find out it was his hub bearing
Old Jul 1, 2003 | 10:15 AM
struppi's Avatar
Default Re: (B16Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">could be your bearing, my boy just changed his axle, and he still heard clicking come to find out it was his hub bearing</TD></TR></TABLE>
Does hub bearing clicking always occur continuously or possibly only when turning? Trying to decide if my clicking may also be coming from the hub bearing.
Old Jul 1, 2003 | 10:23 AM
APEX CRX's Avatar
yeah, if it was the hub it would click or howl whenever its rotating
Old Jul 1, 2003 | 11:58 AM
advanracing62's Avatar
Default Re: (APEX CRX)
did you seat the axles fully? Did you replace the keepers on the axle?
Old Jul 1, 2003 | 02:36 PM
squirrel's Avatar
Default Re: Axle clicking on new axles? (b20guy)
I've got the same problem when I turn sharply in reverse. (I also have a quaiffe)
Still don't know what it is.
Old Jul 2, 2003 | 07:45 PM
b20guy's Avatar
my problem only happens on sharp turning
Old Jul 2, 2003 | 08:34 PM
squirrel's Avatar
Default Re: (b20guy)
I'm not sure, but I think thats natural for an LSD. I think one of the ways people check to see if they have and LSD is by turning sharply and listening for clicks
Old Jul 4, 2003 | 01:43 PM
QCKGSR's Avatar
Default Re: (squirrel)
make sure the axel is fully seated sometimes you have to machine the ends of the axels to make them seat fully
ZXiPoZ
May 30, 2012 10:15 AM
blake22
Suspension & Brakes
14
Sep 24, 2010 08:35 PM
nonvteclude
Aug 7, 2006 08:45 PM
mingbling96
Mar 13, 2005 08:14 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
