tps code 7 prob!
Old Jun 30, 2003 | 03:01 PM
Fokis05's Avatar
Default tps code 7 prob!
im throwing code 7 i had to put a new tps on when i did the swap cuz the one it came with was broke i set it a .5 volts and it still throws 7 so i tryed another tps and it still throws code 7 what else could it be? btw i rest the ecu every time.
Old Jun 30, 2003 | 03:26 PM
Fokis05's Avatar
bump need help
Old Jun 30, 2003 | 04:13 PM
Fokis05's Avatar
anyone?
Old Jun 30, 2003 | 04:31 PM
quik1's Avatar
Default Re: (Fokis05)
Should be set to 0 volts at idle.
Old Jun 30, 2003 | 04:41 PM
Fokis05's Avatar
i guess its worth a try 1st time ive heard that
Old Jun 30, 2003 | 04:44 PM
Fokis05's Avatar
cant get 0 volts at idle!
Old Jun 30, 2003 | 05:00 PM
Hondaaccordvtec's Avatar
With the ingition switch to the "on" position, what is the voltage? It should be 0.5v as you have stated. Now, turn the throttle rotor to WOT - What is the voltage now? It should be around 4.5v if not, you may have a bad TPS or just need to keep dialing it in.
Old Jun 30, 2003 | 07:12 PM
Fokis05's Avatar
i have like .52 KOEO and around 4.8 with WOT , i've tried two differnt tps and i get the same thing and still the CEL???????????
Old Jun 30, 2003 | 07:27 PM
Ok - now you need to give us more info. What kind of car? Civic? Accord? 'Teg?
Also, stock motor or do you have a swap and if so what motor?
The more info. you can give us, the better as we can give some other troubleshooting tips.
Old Jun 30, 2003 | 09:32 PM
quik1's Avatar
Default Re: (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">With the ingition switch to the "on" position, what is the voltage? It should be 0.5v as you have stated. Now, turn the throttle rotor to WOT - What is the voltage now? It should be around 4.5v if not, you may have a bad TPS or just need to keep dialing it in.
Sorry must have been mistaken.
Old Jul 1, 2003 | 06:43 AM
Fokis05's Avatar
94 civic b18c1 swap p72 ecu, the car runs fine just cant get rid of the CEL
Old Jul 1, 2003 | 10:18 AM
Fokis05's Avatar
bump
Old Jul 2, 2003 | 02:03 PM
Fokis05's Avatar
anyone??????????????????????????????
Old Jul 2, 2003 | 05:24 PM
Yougod's Avatar
Since it is not a recommended procedure to remove TPS's from Honda throttle bodies, the only sure-fire way to get rid of this code is to install another TB with the TPS still rivetted on it.
I had this problem with my swap. Rather then wasting my time (or AFTER wasting my time) ohmin and voltin I decided to head up to my workplace's spare parts room where I found a suitable TB. After the switch, the code was no more.
Note that this was all after I swapped TB's and TPS's that were lying around just to be certain that it wasn't just a bad combination.
Jej2386
Feb 18, 2010 11:27 AM
ludacole
Aug 13, 2005 11:59 PM
phatrick2332
Jul 22, 2004 08:44 PM
smokinsi
Jul 18, 2004 05:09 PM
IWearMyKswiss
May 24, 2003 02:01 PM
