IB blocks
Old Jun 30, 2003 | 10:34 AM
eg686's Avatar
Default IB blocks
im interested in buying the b18b block from them, its built. im thinking of buying a b16 head ad upgrade the valvetrain. can thsi built block and head with upgraded valvetrain take high reving and such?
i know i will need the the complete head.
Old Jun 30, 2003 | 11:10 AM
All Motor Rex's Avatar
Default Re: IB blocks (nocaryet)
IB does good work. High reving should not be a problem with a built block and head.
Old Jun 30, 2003 | 11:28 AM
eg686's Avatar
Default Re: IB blocks (All Motor Rex)
is here any more things i need to upgrade on my head to take a beating?
EDIT: i plan on spraying a big shot liek 100 or 125. will sleeving be nessary?
Old Jun 30, 2003 | 12:18 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocaryet &raquo;</TD></TR><TR><TD CLASS="quote">is here any more things i need to upgrade on my head to take a beating?
EDIT: i plan on spraying a big shot liek 100 or 125. will sleeving be nessary?</TD></TR></TABLE>
what compression?
You can get away with a 100-125 shot on a built stock block no problem.
Old Jun 30, 2003 | 08:40 PM
eg686's Avatar
Default Re: IB blocks (vtecvoodoo)
so the valvetrain is the only thing i need to make a built head to take high reving?
lowest compression they have is 9 but with a b16 head and 93 octane fuel it should be pretty high. can i spray then? if i have a built block like this, what kind of conditions will i need to sleeve? turbo?
i want to go FI cuz NA is expensive.
Old Jun 30, 2003 | 09:58 PM
AllMotorNonVTECB20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocaryet &raquo;</TD></TR><TR><TD CLASS="quote">so the valvetrain is the only thing i need to make a built head to take high reving?
lowest compression they have is 9 but with a b16 head and 93 octane fuel it should be pretty high. can i spray then? if i have a built block like this, what kind of conditions will i need to sleeve? turbo?</TD></TR></TABLE>
Fist off fuel has nothing to do with the actual compression ratio of your engine. Second of all a b18 block that starts at 9.1 compression with a b16 head will only end up being around 9.5, which is definatly not high compression considering a stock b16 has 10.2. Also with compression this low there is not need to rev high because you wont make anypower.
Old Jun 30, 2003 | 10:02 PM
i want to go FI cuz NA is expensive.</TD></TR></TABLE>
Old Jul 1, 2003 | 11:36 AM
eg686's Avatar
Default Re: IB blocks (AllMotorNonVTECB20)
so i can just buy a built block from IB, put on the complete b16 head, fuel upgrades, and i will be able to spray 125 shot?
oh, this thread changed to a FI tread. sorry
Old Jul 2, 2003 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocaryet &raquo;</TD></TR><TR><TD CLASS="quote">so i can just buy a built block from IB, put on the complete b16 head, fuel upgrades, and i will be able to spray 125 shot?
oh, this thread changed to a FI tread. sorry</TD></TR></TABLE>
If you can supply the fuel need for a 125 shot a built block form IB will definatly hold it. However you will want a multi-port nitrous system. You can only take a fogger system to 100 shot safely. It is hard to control air/fuel ratios with foggers systems when you are running this much nitrous into the intake tubbing.
BMC125
Sep 12, 2013 02:41 PM
CHEESEYeg6
May 29, 2012 08:26 PM
BoldFart16
25
Feb 20, 2011 04:42 PM
servion
Feb 11, 2003 10:06 PM
