Do I need hi-temp hardware for turbo??
Old Jun 30, 2003 | 08:49 AM
arsenaldragster's Avatar
Default Do I need hi-temp hardware for turbo??
hey guys im piecing together my turbo kit and bought a few misc. nuts and bolts and stuff. My question is do I need HI-temp hardware since its going to be in the engine bay or will hardware from like home depot work fine? I hear some stuff heats up and expands or something.. lmk. TIA
Old Jun 30, 2003 | 09:23 AM
DIRep972's Avatar
Smarter than you
Default Re: Do I need hi-temp hardware for turbo?? (arsenaldragster)
best thing u can do is use studs/lockwashers @ all places possible. I used stainless steel downpipe bolts and they expand when they heat up. It was nice cause they never came out again, but when I had to take the downpipe off it WAS A BITCH X 2! they expanded so much I couldn't break them loose. Stainless steel strips easily so I ended up taking my radiator out so I could get a big *** mexican speed wrench on them to break them loose. after that I went v-band and im loving every minute of it. but yeh, studs/lockwashers I would use high-temp studs in the turbo manifold if u can.
Old Jun 30, 2003 | 10:26 AM
Default Re: Do I need hi-temp hardware for turbo?? (DIRepTial)
Thanks! Do you know where I can get em online or in a kit at?? TIA
Old Jun 30, 2003 | 10:37 AM
Farnsrocket's Avatar
What is a "high temp stud" ? Someone talked about this last year and I think it was just a misconception that such a thing exists. There is no heat resistant steel ......just different grades of hardness and types. ie stainless or a grade 8 etc.
Old Jun 30, 2003 | 12:05 PM
Default Re: Do I need hi-temp hardware for turbo?? (Farnsrocket)
well where can i get a higher grade stud?
Old Jun 30, 2003 | 12:22 PM
DIRep972's Avatar
Smarter than you
ur probably right. I just went to the local specialized hardware store and I told them I needed a stud to handle 800degrees Celcius. they were like and they hooked me up w/ these nice pretty gold ones. I ended up not using them though cause I changed set ups.
Sprockets
Dec 4, 2011 07:15 PM
xtrec02
Aug 2, 2006 02:41 PM
lanojp1
Oct 11, 2004 07:51 PM
silverb18
Sep 14, 2004 09:26 AM
DubyaAye
Feb 10, 2004 03:34 PM
