issues running 8.5:1 not boosted yet??
Old Jun 30, 2003 | 06:57 AM
dingusjt's Avatar
Default issues running 8.5:1 not boosted yet??
i may be purchasing a very well built d16a6 motor buts its compression is 8.5:1 right now however i will probably not be putting a turbo kit until christmas time...so i was wondering how this would affect the engine/driveability being that it is my daily driver..any suggestions??
Old Jun 30, 2003 | 07:20 AM
JDMCRX's Avatar
Default Re: issues running 8.5:1 not boosted yet?? (dingusjt)
Well first of no power its going to feel like a slug.Might want to put the motor and turbo all at once
Old Jun 30, 2003 | 07:22 AM
dingusjt's Avatar
Default Re: issues running 8.5:1 not boosted yet?? (JDMCRX)
i had a feeling that was the case..
Old Jun 30, 2003 | 07:41 AM
mos's Avatar
mos
It will be fine. One point of compression isn't going to cut your power in half or anything.
Old Jun 30, 2003 | 08:51 AM
Doodoo's Avatar
You will be ok, I did for about 8 months. Just feels a bit sluggish at take off but then you are ok.
Old Jun 30, 2003 | 09:29 AM
platinum00's Avatar
Default Re: issues running 8.5:1 not boosted yet?? (Doodoo)
just advance your timing a little. you will be fine.
with that low of compresison you have a little bit you can play with in the timing area.
now once your boosted. PLEASE dont leave your timing advanced.
platinum.
Old Jul 1, 2003 | 11:36 PM
dingusjt's Avatar
Default Re: issues running 8.5:1 not boosted yet?? (platinum00)
could i raise the compression closer to stock using a different head gasket??? or is that just worthless??
Old Jul 2, 2003 | 03:14 AM
platinum00's Avatar
sure if you wanna rip the head off.
use a thinner head gasket to raise the compression.
platinum.
Old Jul 2, 2003 | 06:18 AM
dingusjt's Avatar
well i have some arp studs laying around that i was going to install anyway...any reccomendations on head gaskets that would bring this closer to stock compression???
Old Jul 2, 2003 | 01:24 PM
platinum00's Avatar
sce makes one i think. and mr gasket has some as well. if your only going to use it for a little while till your boosted, i would go with the cheaper one.
Old Jul 2, 2003 | 01:30 PM
Sonny's Avatar
If you use a thin enough gasket to get your compression back, you will alter the cam timing a lot, too.
My engine is 8.5:1, too (stock was 9.5:1). It's a little soft below 4000, but I've advanced the timing quite a bit (stock = 12 BTDC, now = 18 BTDC) and it runs good. I'm looking forward to the turbo.
Sonny
TomCat39
Mar 18, 2015 07:15 AM
007EG
Nov 6, 2007 02:16 PM
tianporn
Jul 28, 2004 12:10 AM
tianporn
10
Jul 26, 2004 11:52 PM
McFly
Mar 29, 2003 12:38 PM
