upgrading IC to 2.5" hurt?
Would upgrading to 2.5" IC piping really hurt performance drastically? Like how much? Would staying with 2.25" be better overall for no less than 12 psi?
[Modified by Slow_ass_4dr, 9:47 PM 7/26/2001]
same air flow in a larger pipe? = reduced velocity in my book (shrug) But I draw pictures for a living....so I dunno...makes sense to me.
Another consideration, while changing pipe diameter does not directly change intake temps, it does increase pressure losses. If you have to increase boost pressure at the turbo to compensate for pressure losses from your plumbing you could effectly have increased air temps while running the same intake manifold pressure. The difference between 2" and 2.25" if probably not very significant though.
[Modified by BigProbe, 8:28 AM 7/27/2001]
piping is ussually at 2.25 for a reason... there is no need to make it bigger unless u are rasing the boost... biprobe is right... the velocity will be slowed down... to add to it... isnt 2.25 about the diameter of the tb about? putting a 2.5" pipe to it kinda defeats the purpose... u see cars with 3" pipes and all... but they also run hi-boost, and big throttle bodies
DamonBoost
Jun 24, 2002 06:03 PM
