whats a good allmotor cam for my set-up (z6)
d16z6
goldeneagle sleeves 80mm bore
11.8 compression
fully ported head with valve job
port match manifold and tb
chipped p28
does anybody know whats a good cam to run with this set-up?
11.8 compression
chipped p28
im running a comp 59300 cam(zex stage2) and it is a really big improvement. the cam is good for turbo or na so its not ideal for just one or the other. i would get a dedicated NA cam, like one that has a fair bit of overlap and some good lift. get some springs too as with a really aggressive cam it will need it, and you can rev up to 9k though i don't reccomend it.
http://www.hadamotorsport.com/....html
look at this site and pick the biggest cam you can find
Modified by allmtr at 11:02 AM 6/30/2003
