Looking for a crank pulley that ONLY has an alternator belt groove?
Old Jun 29, 2003 | 08:42 PM
SiR Kid's Avatar
New User
Default Looking for a crank pulley that ONLY has an alternator belt groove?
Help me out, my 4th gen brothers and sisters. I'm looking for a crank pulley that only has the groove for an Alternator, or just an alternator and one other groove.
Is there anything out there like this that is a factory Honda piece? I don't want a race only part, because I daily frive my little hybrid when I'm not putting it back together.
Thanks, Guys and gals.
Old Jun 29, 2003 | 09:29 PM
johnzm's Avatar
Default Re: Looking for a crank pulley that ONLY has an alternator belt groove? (SiR Kid)
http://www.inlinefour.com makes custom ones with the rubber dampners still intact.
Old Jun 29, 2003 | 09:34 PM
guttedEF's Avatar
Is this for a D or B series. I know that if it's B series, you can use a JDM CTR crank pulley. It's exactly as you're describing. As for D series, nothing OEM that I know of. And I dunno if there's a difference for D and B series pulleys. I doubt it would fit though. I'm sure someone here can answer that question.
Old Jun 30, 2003 | 12:40 PM
Tbone's Avatar
Default Re: Looking for a crank pulley that ONLY has an alternator belt groove? (guttedEF)
The ctr n1 pully has no rubber damper in it. It's not factory balanced either.
Old Jun 30, 2003 | 12:55 PM
keithv's Avatar
Default Re: Looking for a crank pulley that ONLY has an alternator belt groove? (Tbone)
i run an HF one that only has 2 grooves...i wish i had a pic.
Old Mar 11, 2004 | 07:56 PM
DC2-JRSC'd's Avatar
does honda make a crank pulley with only one grove for the cars with no power steering or a/c ? The 89Si has only 2 groves (a/c and alt) but what if it didnt come with a/c? Will it have only 1 grove for the alt belt?
Old Mar 11, 2004 | 08:03 PM
marieT1GRL's Avatar
Default Re: Looking for a crank pulley that ONLY has an alternator belt groove? (dan4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan4g63 &raquo;</TD></TR><TR><TD CLASS="quote">does honda make a crank pulley with only one grove for the cars with no power steering or a/c ? The 89Si has only 2 groves (a/c and alt) but what if it didnt come with a/c? Will it have only 1 grove for the alt belt?</TD></TR></TABLE> yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">The ctr n1 pully has no rubber damper in it. It's not factory balanced either. </TD></TR></TABLE>
Old Mar 11, 2004 | 08:18 PM
DC2-JRSC'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl &raquo;</TD></TR><TR><TD CLASS="quote"> yes
Where can i get one?
Old Mar 11, 2004 | 09:58 PM
Origin's Avatar
in no way am i trying to degrade this post. just wondering what the point is? less weight? more clearance room? thanks.
Old Mar 12, 2004 | 01:38 AM
undefinedcrx's Avatar
Default Re: Looking for a crank pulley that ONLY has an alternator belt groove? (Origin)
Origin: Less Rotating Mass = More Power to the wheels = Good Fun
As far as the pulley, im running an 88-91 HF one. Only has two grooves (Alt. A/C). Im not sure if there was a pulley that has only one groove, but you might want to look into a 88-91 Civic STD Hatchback, or D15B1 pulley. The D15B1 came with no amenities like power steering and A/C. Hope this helps.
b16hybridsol
Welding / Fabrication
24
Jul 9, 2006 12:00 PM
Gearspeed-Performance
Apr 19, 2004 04:23 PM
Hukd Up
Apr 1, 2003 06:34 AM
-16V-
10
Nov 5, 2002 08:08 AM
