CLUTCH PROBLEM PLEASE HELP
Old Jun 29, 2003 | 07:24 PM
whiteboythatcuts's Avatar
Default CLUTCH PROBLEM PLEASE HELP
I JUST PUT A B18A1 IN A 94 VX HATCH MY CLUTCH WORKS FOR ABOUT 5 MINUTES THEN QUITS WHATSUP
Old Jun 29, 2003 | 07:39 PM
Mikey's Avatar
Default Re: CLUTCH PROBLEM PLEASE HELP (whiteboythatcuts)
You need to be more specific. This could be caused from a NUMBER of things. Start simple:
Is your clutch master cylinder full?
Old Jul 10, 2003 | 02:18 PM
Default Re: CLUTCH PROBLEM PLEASE HELP (Mikey)
i didi start simple everything is hooked up prop[erly smartass
Old Jul 10, 2003 | 02:51 PM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteboythatcuts &raquo;</TD></TR><TR><TD CLASS="quote">i didi start simple everything is hooked up prop[erly smartass</TD></TR></TABLE>
First off, learn to describe yourself you dumb ****. You're asking the question and he asked you to be more descriptive. So let me explain morality to you. He is taking the time to try to help you and you lash out at him. I now have to take my time out of my busy day to explain this to you, now why the hell would I want to help an ignorant person like you? However I will anyway.
Do you have a lot of pressure?
Did you bleed the clutch?
What brand clutch?
I would check for leaks on the slave or master cylinder.
It sounds like you might have a hole a leak in the system, or failing slave master cylinders. I would strongly recommend bleed the clutch. Use search to find out the best process.
Good luck **** sucker.
jhonda239
May 20, 2008 10:14 AM
civicpark81
Nov 1, 2007 08:18 AM
4LugR
May 9, 2005 10:07 AM
Hatch It
Jan 18, 2005 06:54 AM
gsr camel
Sep 13, 2001 12:05 PM
