RC 310cc injectors don't fit!!!
Old Jun 29, 2003 | 04:56 PM
b20ek's Avatar
Default RC 310cc injectors don't fit!!!
Ok I was wondering if anyone has ever had a problem with RC injectors not fitting into the manifold? Mine fit the fuel rail but they don't fit in the manifold. They are 310cc and I'm using a 94 Skunk 2 IM.
Modified by b20ek at 6:57 PM 6/29/2003
Old Jun 29, 2003 | 05:01 PM
MachAF's Avatar
Default Re: RC 310cc injectors don't fit!!! (b20ek)
yeah I had problems at first.
They aren't suppose to fit like stock injectors.
put them in the fuel rail then tighten the fuel rail down, not too tight cuz you'll break the fuel rail stud.
Old Jun 29, 2003 | 05:11 PM
b20ek's Avatar
Default Re: RC 310cc injectors don't fit!!! (MachAF)
anyone else had any problems?
Old Jun 29, 2003 | 05:12 PM
b18cTurbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">yeah I had problems at first.
put them in the fuel rail then tighten the fuel rail down, not too tight cuz you'll break the fuel rail stud.</TD></TR></TABLE>
the way to do it like i did too
Old Jun 29, 2003 | 05:15 PM
b20ek's Avatar
Default Re: RC 310cc injectors don't fit!!! (sleeper007)
so you tighten them down untill they press themselves into the manifold?
Old Jun 29, 2003 | 05:57 PM
b20ek's Avatar
please help.
Old Jun 29, 2003 | 06:03 PM
RyanEJ8's Avatar
Pull out Helms or Haynes and look up the torque specs for the fuel rail. On my D16 it was 109 in-lbs. I think.
Old Jun 29, 2003 | 06:09 PM
b20ek's Avatar
Ok I'm not trying to find out the torque specs, although 109in/lbs equalls about 8.9 ft/lbs which means hardly any torque at all, which means that the injectors should not have to be PRESSED into the manifold. I guess I'm just an idiot I don't know.
Old Jun 29, 2003 | 06:15 PM
Bspec18's Avatar
just press firmly on the rail, they'll go in smooth, i have Skunk2 IM, with 310's and a AEM fuel rail. had no problems... did u put the new bushing supplied with the injectors ?
Old Jun 29, 2003 | 06:18 PM
Chiovnidca's Avatar
Default Re: (Bspec18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote"> did u put the new bushing supplied with the injectors ?</TD></TR></TABLE>
Or read the directions that came with them?
Old Jun 29, 2003 | 06:23 PM
b20ek's Avatar
Default Re: (Chiovnidca)
ok maybe this is the problem. I bought the injectors used and all I got was injectors. No bushings or anything like that. I figured all I needed was the rubber seal that fits into the manifold and the injector.
Old Jun 29, 2003 | 06:43 PM
Chiovnidca's Avatar
Default Re: (b20ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek &raquo;</TD></TR><TR><TD CLASS="quote">ok maybe this is the problem. I bought the injectors used and all I got was injectors. No bushings or anything like that. I figured all I needed was the rubber seal that fits into the manifold and the injector. </TD></TR></TABLE>
Nope, they use a different seal and mount a little different.
Old Jun 29, 2003 | 06:51 PM
b20ek's Avatar
ok thanks for curing my confusion.
airwalk07143
Dec 30, 2008 05:56 AM
1990si
Mar 12, 2007 08:28 PM
Boosted_Coupe
Jan 27, 2007 09:14 PM
MotorMatrix.com
Feb 18, 2003 07:09 PM
Jamison
Jul 9, 2002 05:08 PM
