y8 mani problems.
Old Jun 29, 2003 | 02:17 PM
mooseknuckle's Avatar
Default y8 mani problems.
I attempted to install my y8 mani on y7. PROBLEMS!
Once I took the old y7 mani off. I got the y8 all set to be installed
I put the vaccums on and coolant lines in place. And connected all the sensors.
But I have nothing for the tb lines. They disappeared. Ive looked on my buddies
car and I dont have these lines. My car isnt running 2 rich. But idles really bad
it does between 1500-3000. Dont know what to do. I need HELP anyone know
thats up with it. I'm trying to get this dude to help me out but I can't get in touch
with him.
Drew
Old Jun 29, 2003 | 03:35 PM
IDriveHonda's Avatar
Default Re: y8 mani problems. (mooseknuckle)
Are you talking about the lines that run to the IACV? Your problem sounds more like a vaccum leak to me. Does the idle fluctuate?
Old Jun 29, 2003 | 03:38 PM
Airbag Club's Avatar
what year intake mani did it come off of? reason is because if it is a 99-00 intake mani, you might need to plug up those air injection holes...check the link below.
https://honda-tech.com/zerothread?id=546057
Old Jun 29, 2003 | 07:14 PM
Happyman's Avatar
Default Re: y8 mani problems. (IDriveHonda)
Yea his idle goes up and down consistantly. I have a 1997 y8 in my car and we used it as sort of a schmatic but there were 2 fittings on his mani/tb that I couldn't see on mine. Not sure why but perhaps it is like that guy said about the 99-00 y8. Bump for drubie.
Old Jun 29, 2003 | 07:37 PM
hardboiled egz's Avatar
Did this IM come off a AUTOMATIC or MANUAL?
Old Jun 29, 2003 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveHonda &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about the lines that run to the IACV? Your problem sounds more like a vaccum leak to me. Does the idle fluctuate?</TD></TR></TABLE>
Came off a 5spd. Anyone know what to do?? I need someone thats done this
before, and can help a brotha out.
Drew
Old Jun 29, 2003 | 07:48 PM
EVIL Hx Coupe's Avatar
If it's a 99-00 there was a recent post here that show the holes you got to plug.
Old Jun 29, 2003 | 07:50 PM
Thats the link to the Post.
Old Jun 29, 2003 | 09:14 PM
TheAutoboxer
Guest
Posts: n/a
Default Re: y8 mani problems. (EVIL Hx Coupe)
guys.. please read up.. it's not a 99.... i would say double check all your fittings.. make sure the map/tps sensor is connected right.. nothing loose.. also are you using a y7 or y8 intake gasket ?
Old Jun 30, 2003 | 12:46 PM
Default Re: y8 mani problems. (menkio)
y8 gasket.
Old Jul 1, 2003 | 08:09 AM
i used a y8 gasket on the manifold. But i still dunno where the vaccum lines go on the TB.
Old Jul 1, 2003 | 08:20 AM
Turbo Powa's Avatar
Is that a y7 TB? Is your car a auto or 5 speed?
Old Jul 1, 2003 | 08:30 AM
Default Re: y8 mani problems. (Panda EK)
i used the y8 tb and its a 5spd.
Old Jul 1, 2003 | 08:31 AM
Turbo Powa's Avatar
and you said there are no coolant lines?
Old Jul 1, 2003 | 08:36 AM
JaeOne3345's Avatar
how many wires go into the plug on the y7 iacv vs the y8 iacv?
Old Jul 1, 2003 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda EK &raquo;</TD></TR><TR><TD CLASS="quote">and you said there are no coolant lines?</TD></TR></TABLE>
i have no lines connected to my tb. Just the 3 sensors.
y7 iacv vs the y8
on the Y7 (3 wire) and the Y8 (2 wire)
Old Jul 1, 2003 | 08:43 AM
Turbo Powa's Avatar
use the y7 TB on the Y8 Mani... cover the IACV with a gasket. All you need to do is unscrew it and place a gasket over the holes. Once you do that and use the Y7 tb there will be no leak. If you just use the Y8 mani and dotn plug up the IACV on the Y8 there will be a problem. Use the Y7 tb and y8 mani(oplugging the IACV) then you will be set
Old Jul 1, 2003 | 08:48 AM
i'll still have no vaccums to the TB tho?
Old Jul 1, 2003 | 08:49 AM
Turbo Powa's Avatar
there shouldnt be vaccum lines. Its should be coolant lines
Old Jul 1, 2003 | 08:52 AM
thats wut i meant. Theres no coolent lines going into my tb.
Old Jul 1, 2003 | 08:53 AM
Turbo Powa's Avatar
If you want to take care of the IACV problem do what I listed. You maybe having a problem because of that
There has to be coolant lines. Can you take some pics of the TB then? Maybe I can help you from there?
Old Jul 1, 2003 | 08:59 AM
true, I might have those lines connected somewhere on the Mani instead of the TB.
Old Jul 1, 2003 | 09:01 AM
Turbo Powa's Avatar
Let me know what I can do for you. I'm in the NEW YORK area.
Old Jul 1, 2003 | 09:08 AM
turbotime's Avatar
luckily im in the midst of doing a y8 swap so i can tell you where all those lines go. Ok there should be a line coming from the waterpipe right underneath the mani to the leftmost hole in the IACV. The other hole on the IACV goes to your TB, the side facing the firewall. The other side facing the grill goes to the small port on the coolant bypass line. That should do it, if you need anything else PM, becuase i've done this
Old Jul 1, 2003 | 10:24 AM
Default Re: (turbotime)
I replaced the TB with the one from the y7. The idle jumps back and fourth
between 1500-2500. So there has to be a vac leak. I'm just doing something
wrong. I snapped a couple pics.
Dont know if these will help but here:
I couldn't find those coolant lines for the TB. I really need some help. If anyone
wants to give me a hand. Im in the NJ, Princeton area. Im still gunna try and
figure this out but as of right now i dunno what else to do.
Thanks Drew
