what are the proper ohm values for b16a1 knock sensor, oil pressure and vtec solonoid
i have no vtec after my b16a1 swap into 89 si hatch.
all wiring seems corect so i need to test the resistance of the sensors i wired in.
what are the correct values for properly working:
vtec solonoid
oil pressure
knock sensor
please help if you know or have a shop manuel for b16a1 motor
all help appreciated
ben
vtec solonoid
oil pressure
knock sensor
ben
I wouldnt worry about ohm readings to much. If its not working...its just not working. Something isnt/wasnt done right on the wiring side or you dont have sufficient amount of oil pressure. Dont worry about the knock sensor..it is not needed for vtec activation. P30 or PWO ecu? Check engine light on? If its is then try these.
1. check wiring for continuity from the ecu to the sensor
2. make sure the vtec pressure switch is grounded
3. double and triple check that the wires have been placed into the harness at the correct place. ive been doing this for ten years and still will make a mistake every once and a while.
4. is the speedo working and there isnt another cel.....a map cel or other sensor diables the vtec function.
If all this is right and you dont have a check engine light on then it may be meachanical.
It requires a certain amount of oil pressure to activate vtec. Possible oil pump problem or bearing clearance issue. These all need to be addressed before trying to figure out ohm readings.
Pm if you need further assistance. Good luck
well im using a 90 itr tranny. how do i make my si speedo cable work with it???
the speed sensor thing on the tranny is different and has two tubes on it.
do i need an itr speedo cable?
thanx you've been real helpful
can i pull the speedo sensor off my d16 tranny and attach it to my ls tranny?
that way i can use a civic speedo cable, since all the integras at the yard have been raped to hell. will a ls speedo cable even hook up to my dash speedo?
okay. now i'm a little confused. i'm running a pr3 on my d16z6 in my91 crx and i've managed to get rid of all the codes except for the knock sensor. i'm pretty sure it's not going into vtec, and assumed the knock sensor code was the problem. whether it is or not, i'd like to fix the problem so i can get rid of my CEL. what do i have to do to convince my ecu that it's there without having to have the block tapped for the sensor.
Freeltec
Jun 1, 2004 05:09 PM
