Is this what a blown head gasket looks like?
This is what I found when I took my head off.
The white areas are powdery, which I'm assuming its burnt coolant. So does this look blow to you? Does anyone have a pic of a blown head gasket? Thanks.
Hard to tell due to quality of picture......but I dont see anyting that looks like it has blown through. Usually youll find an extremly dark/black mark between the cylinders or cylinder to water jacket. Gasket material comes off naturally due to heat but without and actuall break with black exhaust like powder its not blown.
When I pulled mine it didnt really look bad either, there was a leak in between the layers of it. But the #1 piston was blinging as opposed to the other 3(indication of coolant leaking in) Replaced the hg and my problems were gone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow »</TD></TR><TR><TD CLASS="quote">So does this look blow to you</TD></TR></TABLE>
lmao
lmao
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow »</TD></TR><TR><TD CLASS="quote">This is what I found when I took my head off.
The white areas are powdery, which I'm assuming its burnt coolant. So does this look blow to you? Does anyone have a pic of a blown head gasket? Thanks.</TD></TR></TABLE>
looks like Cocaine all right
usdmftw
Jan 19, 2011 08:34 PM
DelSol-B-18
Apr 8, 2005 06:46 AM
