new zex nitrous air intake filter? good bad?
Hi, anyone used or read about this...Im buying a zex kit and i think this filter would be a good idea since u dont have to drill and its a simple disconnection, what do u all think? thanks
an air filter is an air filter, generally.. but k&n is usually the best. but not knowing that, good luck with the nitrous man. be careful
I think hes talking about that new filter made by ZEX that has the nitrous nozzle plumbed directly into it-->
http://www.zex.com/Base/Images...1.jpg
looks pretty cool!
but depending on where your filter is placed(ie- on the end of a CAI pipe)it might be more efficient to drill near the the TB like normal
looks pretty cool!
Looks pretty cool to me. Im no nitrous expert, but for certain applications, I believe it is beneficial to spray as far away from the TB as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX »</TD></TR><TR><TD CLASS="quote">
looks pretty cool!
but depending on where your filter is placed(ie- on the end of a CAI pipe)it might be more efficient to drill near the the TB like normal</TD></TR></TABLE>
its better to be as far away from TB as possible to allow proper mixture of air/n2o
looks pretty cool!
but depending on where your filter is placed(ie- on the end of a CAI pipe)it might be more efficient to drill near the the TB like normal</TD></TR></TABLE>its better to be as far away from TB as possible to allow proper mixture of air/n2o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob18a1 »</TD></TR><TR><TD CLASS="quote">
beat me to it.
btw: you might get more help in the FI forum.
</TD></TR></TABLE>beat me to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX »</TD></TR><TR><TD CLASS="quote">interesting, does that apply to dry setups only?</TD></TR></TABLE>
Yah... that way it also cools the intake charge much more than spraing right at the TB.
would u need the other **** to get this working....like in other words can you just buy this filter thing a jet a bottle and a WOT activator and spray???????or do u need other stuff like the standard kit for the acura.
it isnt a bad thing but as far as spraying as far fromn the tb as possible....it doesnt matter. in fact the further away you spray the less torque you will gain. I guess this would be a personal preference thing
i think it is better to put the n2o nozzle on the end of the CAI. Even though the speed that the air flows through the intake it still will make a better air/n20 mixture rather then having it 6-8 inches away from the TB like ZEX says to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr »</TD></TR><TR><TD CLASS="quote">it isnt a bad thing but as far as spraying as far fromn the tb as possible....it doesnt matter. in fact the further away you spray the less torque you will gain. I guess this would be a personal preference thing</TD></TR></TABLE>
Now why do you say you will gain less torque by having the nozzle away? i don't understand? expalin your theory?
looks pretty cool!
looks pretty cool!
but depending on where your filter is placed(ie- on the end of a CAI pipe)it might be more efficient to drill near the the TB like normalX2, in getting a dry Zex Kit also and saw this filter, initially thought sweet! I'll try that. But I agree with the above quote since most installs recommend drilling around 6" from the tb intake or directly on the tb. I think having the spray so far from the intake could potentially lose some of the nitrous benefit but I'm only speculating.
Drag-On23
Mar 13, 2005 07:20 PM
