wooh! cam install 95% complete
Old Jun 28, 2003 | 08:30 PM
216.226.142.95:27016's Avatar
Default wooh! cam install 95% complete
hope it doesnt explode [crosses fingers]
ill post back if the engine survives
Old Jun 28, 2003 | 08:58 PM
AWDxBOOST's Avatar
Default Re: wooh! cam install 95% complete (216.226.142.95:27016)
fun fun...tells us how it goes
Old Jun 29, 2003 | 12:54 AM
Default Re: wooh! cam install 95% complete (ls_teg)
ummm it ticks
i expected it since i didnt do a valve adjustment but i will do it soon as i can.
i dont think i bent any valves though since the idle is fine, it doesnt fluctuate theres no dips in power. i havent however stepped on the gas that hard since the ticking is scaring me.
Old Jun 29, 2003 | 01:05 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">ummm it ticks
Valve clearance. You gotta perform a valve adjustment. Peace of cake and the butt dyno will notice it.
You did torque all the cam caps back to spec right?
Old Jun 29, 2003 | 01:09 AM
Broken Gearbox's Avatar
Default Re: wooh! cam install 95% complete (P1mpSlap)
what kind of cams you drop in anyways.
Old Jun 29, 2003 | 01:10 AM
P1mpSlap's Avatar
and how you get that timing belt back on
Old Jun 29, 2003 | 01:34 AM
B00ST2nR's Avatar
Default Re: (P1mpSlap)
after a valve adjustment, your motor will sound ALOT better... Mine did.
Old Jun 29, 2003 | 01:50 AM
im a paranoid *** about breaking stuff so i wanted things to be just right. the thing that took me the most is making sure its at TDC.
as for the timing belt, someone said something about theres a rubber plug that i can take out to access it and i did that. the problem with this is that its still hard to access with a ratchet. so i took things off, ps tank, ps assembly, cruise control and i was even going to take out the a/c since the belt is getting in the way. i also tried to take out the driver side engine mount which i later found out didnt have to be taken off. so now i cant put it back on, problem after another eh? anyone know how to get the 2 mounting holes to line up?
the t-belt is tension on the intake side but loose on the exhaust side gear so i have to look into that, any suggestions?
i hope i didnt **** up the installtion, i drove it around for a while but i was scared to rev it up because of the noise, i imagine the cam caps flying off and punturing through the valve cover.
as for the cams, toda c
but in reality, CTR intake and exhaust cam
Old Jun 29, 2003 | 03:33 PM
.RJ's Avatar
.RJ
Default Re: (216.226.142.95:27016)
You either need a helms or need to pay someone to do this for you so you can watch.
1 - you need a jack under the oil pan (w/ a block of wood) to get hte motor in proper position
2 - you dont need to take half that chit off
3 - always always always do a valve adjustment w/ new timing belt or cams
4 - you need to pull on the tensioner to get it 'tight' while you tighten the tensioner bolt. Run it like that and the cam is going to skip a tooth or belt is gonna break.
Old Jun 29, 2003 | 03:57 PM
Default Re: (.RJ)
1. i got a helms for a 84 integra and it doesnt go over techniques on how to put the mount on
2. no way around it unless i have super skinny arms and tools to take off the crank bolt for the lower t-belt cover to be removed. the mistake i did make is taking off the engine mount.
3. ill be doing the valve adjustment soon, before then the car will be sitting
4. yeah ill give that a try, how can you tell if your "off a tooth" and how can this be fixed? im also going to check my ignition timing to see if that is affected it any ways.
thanks guys!
Old Jun 29, 2003 | 04:10 PM
.RJ's Avatar
.RJ
If you're off a tooth the car will run like chit and the cams wont line up properly... even if they line up the crank could be off a tooth. If you've been futzing with it, it wouldnt be a bad idea to pull the crank bolt/lower cover off and take a look. Only takes 10 minutes if everything else is off.
Old Jun 29, 2003 | 04:14 PM
Default Re: (.RJ)
if only if i had an impact gun. i did the install bymelf and my hands are all cut up from wrenching for a couple of days. the only time i was able to work on my car was late in the evening.
2ndchirp
Jul 24, 2008 10:30 AM
hondachris1994
14
Jan 24, 2007 05:29 PM
Baron55
Aug 9, 2005 03:27 PM
BLK99VTECR
Mar 1, 2004 05:13 AM
h46it
Apr 3, 2002 09:09 PM
