Low compression pistons and check engine light???
Old Jun 28, 2003 | 07:27 PM
Prelude Vtec 23's Avatar
Default Low compression pistons and check engine light???
Just wondering if anyone ever got a CEL for having some low comp pistons in their car. Cuz I just started my car and my CEL is throwing codes of 71, 72 and 73 which is misfire detected in cylinders 1, 2, and 3. One of the reasons is it says it may be cause by low comp. Just wondering if that may be the reason so I can try to narrow it down to what it could be cuz their are several other reasons also that may cause it.
Old Jun 28, 2003 | 09:28 PM
LudeyKrus's Avatar
Default Re: Low compression pistons and check engine light??? (Prelude Vtec 23)
Why do you have lower compression pistons in there? I'm hoping it's boosted....
If it's not boosted and you're still running those pistons, it may not be firing the plugs.
Old Jun 29, 2003 | 05:55 AM
Default Re: Low compression pistons and check engine light??? (LudeyKrus)
Well I started the car w/out the turbo just to see if it was able to start and run ok. So what you are saying is that it might me be due to the lower comp pistons the cylinders are misfiring?
Old Jun 29, 2003 | 07:29 AM
PrecisionH23a's Avatar
i have never heard of that happening. I ran N/A with 9:1's for roughly 1000 miles and never threw that code. Something else is wrong.
Old Jun 29, 2003 | 07:30 AM
Default Re: Low compression pistons and check engine light??? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">i have never heard of that happening. I ran N/A with 9:1's for roughly 1000 miles and never threw that code. Something else is wrong.</TD></TR></TABLE>
Thats what I wanted to know thanks.
Old Jun 29, 2003 | 09:09 AM
testing 1 2 3's Avatar
Do you think playin w/ the plug gap could help any? I'm thinkin it sounds like it's not gettin enough fuel in there w/ the lowered compression, but i've never thought about low comp. on an n/a motor.
Old Jun 29, 2003 | 06:02 PM
atlprelude01's Avatar
ive been getting this code lately as well, I only have bolt ons on my h22
Old Jun 29, 2003 | 06:39 PM
sslude's Avatar
Default Re: (atlprelude01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atlprelude01 &raquo;</TD></TR><TR><TD CLASS="quote">ive been getting this code lately as well, I only have bolt ons on my h22</TD></TR></TABLE> you dont have low comp pistons and your'e getting this code? you have a whole different problem, and need a whole differnt thread
Old Jun 29, 2003 | 07:11 PM
Ive had a honda tech tell me misfiring could be plugs and some ase certified asians. It might not be though its bothering me and I did make a thread and pretty much got no help. Thats why i budded into this one a lil bit.
Old Jul 8, 2003 | 11:48 AM
Ok guys, my car has been running fine for about 200 miles w/ no check engine light. But it just came on again this time it says all cylinders are mis-firing. The car sounds fine and runs and idles smooth. Should I be concerned? Do you guys think it is because of the lower compression pistons its miss firing and is it related to the gapping of the spark plugs? Please help and give me some suggestions on what to do. Thanks.
Old Jul 9, 2003 | 06:00 AM
Default Re: (Prelude Vtec 23)
Nobody has any suggestions of what else I can do to troubleshoot this?? I already see that some people have run low compression pistons and no check engine light came on so what else can I do to try to figure this out??
legoman
Jan 25, 2005 01:49 PM
94gsr18kid
Jan 25, 2005 09:02 AM
My_EP3
Apr 6, 2004 06:27 PM
Prelude Vtec 23
Jul 10, 2003 03:26 PM
jap-spec
Jan 16, 2003 09:35 PM
