This might sound stupid, but I am thinking on taking out the B for a D
I have an LS swap and have been thinking on swapping in a d16y8. For some reason I have this urge to build an all motor D. What do you guys think? Whats the most HP I could get from an all motor D. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMcivicEF »</TD></TR><TR><TD CLASS="quote">I have an LS swap and have been thinking on swapping in a d16y8. For some reason I have this urge to build an all motor D. What do you guys think? Whats the most HP I could get from an all motor D. Thanks</TD></TR></TABLE>
Why is it stupid?? Your just triyng something different nothing worng with that. There is all sorts of power in a D-series you just have to have the money to unleash it.
hell yeah. There are quite a few people that have built some bad-*** D's. I think the fastest D ran a high 10 in the 1/4 but I'm not sure. Hot Rod Honda had a crx with a low 11 second D in it about 4 years ago
I just pulled my B16 and replaced it with a d16a6.....of course I am doing "something" to the B....I am happy with the D until the B is done....
i'm thinking of doing sortof the same thing i hate my b18a1 except i want to do d16a6 block,89 teg pistons/rods,92 ex head gasket,cbr individual throttle bodys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX »</TD></TR><TR><TD CLASS="quote">Just remember it's fun beating the "mighty B" with a D
Yep there is always bragging rights there!!
</TD></TR></TABLE>Yep there is always bragging rights there!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 »</TD></TR><TR><TD CLASS="quote">
hell yeah
i brag a lit every time i go to the track and beat that guy with the red crx and B16A swap
and my friend with the ZC swap on his CRX , and my other buddy with a B16A2 in his CRX...
they all get pist bc i only got a Z6...
</TD></TR></TABLE>hell yeah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx »</TD></TR><TR><TD CLASS="quote">i'm thinking of doing sortof the same thing i hate my b18a1 except i want to do d16a6 block,89 teg pistons/rods,92 ex head gasket, cbr individual throttle bodys
So you've tapped the secrets of the ITB swap?
Let me know how you rigged your set up so I can campare it to others.
</TD></TR></TABLE>So you've tapped the secrets of the ITB swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">How can you not "notice a difference?" There must be something wrong with your engine.
Blaze</TD></TR></TABLE>
Yeah..there should be a butt load more tq in the b. Wonder whats wrong.....
I'm beginning to be happy about my choice of sticking with the D-series vs going B18B... My motor is extremely light, yet it puts out quite a bit of torque and high-end horsepower. However, I had to invest TONS of time, money, frusteration and research into my swap to get it to run the way it is running now. There is a LOT of fine-tuning problems that you have to deal with to get SOHC VTEC motors working properly on OBD-0 vehicles.
Even now it still has more potential, I'm thinking A6 pistons to bump up the CR to 11:1 - heh, it's already a stout motor, and with the higher compression it will be a complete beast.
My b18a made a huge difference over the D, but it was a d15 and not a d16. You can tell by quarter mile times if it helped, and I dont think a D16 with I/H/E would run a 14.7. Something has to wrong with your engine. Anyway back to the D power, if I did higher comp pistons, a cam, port and polish, header, intake, and exhaust about how much hp would I be around. Also what pistons can I use for higher compression? Someone said that making a fast D is expensive, is this true? One of the reasons I have thought about doing this is because I thought it would be cheaper thank a B. I am looking for 13 second timeslips, what would I need to have done to do this? When fully built for an all motor application will a d16y8 make much more power than a fully built d16y6? Thanks
we need this stuff to be a sticky or something, I seem to post it at least 3-4 times amonth if not more; anyhow........
https://honda-tech.com/zerothread?id=186192 thread about pistons
http://www.knology.net/~jediklc/D.htm d series comp calculator
http://nicotine.golden.net/D-Series/dseries.xls d series info
HTH
HTH
well the d16a6 had some parts on it and the b18a1 is basically stock plus the ls tranny is ghey compared to the si i previously had
I love my stock dx motor in my '90 DX it is a beast. I beast my coworker's 02 EX with it. HAHAHA. It is a really big turd but it keeps me out of trouble. I might be putting a D16A6 back in my CRX for awhile till I get the new motor done.
well i'm gonna have a ZC in this week instead of the b18a that i'm going to turbo till i finish building the a6/y8
All i can say is go check out http://www.zex.com
D16a6 mini me setup trurbo and NOS.
The engine, with 18 lbs. of boost and a 100 hp shot of nitrous, made 412 hp to the wheels at 6900 rpm and 365 ft. lb. tq. to the wheels at 6500 rpm.
5.6.01
ZEX™ wins NIRA at Englishtown!
Official race results are 10.883 e.t. at 132.21 mph!
5.6.01
mmcclint
14
Apr 2, 2013 04:59 PM
96electronH
10
Sep 18, 2007 07:13 PM
