bent crankshaft pulley :0
Old Jun 27, 2003 | 11:26 PM
See Are X's Avatar
Default bent crankshaft pulley :0
I just finished installing a 96 LS motor in my crx. And I noticed that the crankshaft pulley is wobbling a little when the engine is on. I dont know if I bent it during the swap or if the motor was already like that. Is this safe to drive on for a while? Can I just replace the pulley?
Old Jun 27, 2003 | 11:36 PM
SIRX's Avatar
Default Re: bent crankshaft pulley :0 (See Are X)
yes you can replace it. If it's not to bad you should be safe to drive it. The worse thing that would probably happen is you'd throw the alternator belt
Old Jun 29, 2003 | 10:13 AM
See Are X's Avatar
Default Re: bent crankshaft pulley :0 (SIRX)
At idle I can see the pulley moving side to side about 2mm. At higher RPMs it goes away. Is this bad for my bearings in the motor? I dont think i'll have time or the money to fix it right away
Old Jun 30, 2003 | 08:13 PM
See Are X's Avatar
bump
Old Oct 10, 2004 | 02:15 PM
jsooke's Avatar
See Are X .....
Did you figure this out or get a reply????
Just installed a swap (d16z into '89 DX) and noticed same thing with the pulley and doing a search came up with this post.
Jay
Old Oct 12, 2004 | 03:54 PM
Death_to_Thieves's Avatar
Default Re: bent crankshaft pulley :0 (jsooke)
I wouldnt drive it like that. You could ruin the crank if the pulley wobbles alot and ruins the journal for the keyway. Check it out and see whats causing before you drive around alot like that
crxaddikt
Jun 20, 2014 06:11 PM
tolowhb
Sep 20, 2009 10:18 AM
crxhybrid85
Feb 27, 2006 06:27 AM
Hockey27925
Jun 16, 2005 04:18 PM
recklessfour
Jan 10, 2005 11:15 PM
