b20 idle prob
Guest
Posts: n/a
did a search no help..i have a b20b in eg hatch.. with d series harness.. car runs fine, but when it is cold started. idle sets at 2000rpm for a while, as it gets a little warmer at about 1300rpm and jumps to 18 back and fourth for a while. then when it is finally wam it idle fine.. i changes roter cap wires etc.. checked iacv and that porp under throttle body.. any help thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangb2023 »</TD></TR><TR><TD CLASS="quote">did a search no help..i have a b20b in eg hatch.. with d series harness.. car runs fine, but when it is cold started. idle sets at 2000rpm for a while, as it gets a little warmer at about 1300rpm and jumps to 18 back and fourth for a while. then when it is finally wam it idle fine.. i changes roter cap wires etc.. checked iacv and that porp under throttle body.. any help thanks</TD></TR></TABLE>
it is normal for the idle to jump to 2k RPMs when its cold,..its just the ECU warming up the motor,....as for the idling jumping,...run a search for something like "erratic idle" or something like that,...i think its the fast idle but im not sure,..the fast idle may just need to be tighten
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage »</TD></TR><TR><TD CLASS="quote">Get a new IAC Valve from Honda. </TD></TR></TABLE>
i dont think he should do that,..he didnt say anything about throwing a code for the iACV,...he might just need to clean the screen
Scott Little
Nov 12, 2015 01:06 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
