HID help
Old Jun 27, 2003 | 09:38 PM
GhettoBrawls's Avatar
Default HID help
i bought a phillips hid kit and i hooked up all the wiring but for some reason the hid bulbs only came with a 2 prong plug - my stock harness has 3 prong plug. when i hooked everything up the lights wouldn't come on - has anyone else had this problem? or know a quick fix?
Old Jun 27, 2003 | 09:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID help (GhettoBrawls)
your stock harness has 3 prongs because the bulbs are dual filament for both low and high beam (plus ground). You will not have high beam w/ HID (unless you got a kit that moves the bulb or the shield).
You need to wire up the low beam power wire and the ground wire to the ballast.
Old Jun 27, 2003 | 09:53 PM
crucial si's Avatar
one ground, one beam.
Old Jun 27, 2003 | 10:10 PM
now that i know its not the harness plugs - any other suggestions??
Old Jun 27, 2003 | 10:51 PM
bump
Old Jun 28, 2003 | 09:09 AM
enrique's Avatar
on my ek the black is for the high beam. figure out what goes to waht with the 2 wires left and our set. make sure you check the under dash fuse to make sure you haven;t blown them. upgrade to at least 20 while you are at it. good luck
Rodney Williams
Lighting
Oct 30, 2014 08:45 PM
_EF9
Lighting
Nov 25, 2012 05:58 PM
bce22
Mar 4, 2009 06:33 PM
cilvia
Lighting
Jan 20, 2008 06:32 PM
btcca4
Audio / Security / Video
Jan 31, 2005 12:22 PM
