how do I know if....
Old Jun 27, 2003 | 03:30 PM
projectEK9's Avatar
Default how do I know if....
I need to adjust my valves....cuz right now I hear a slight click noise coming from my engine when in neutral..... I asked my friend and he immideatly said adjust your valves...but I just wanted to make sure.....
Old Jun 27, 2003 | 03:40 PM
SantaCruz92Si's Avatar
adjust your valves.....
valves click..... at least adjust them and while your out it make sure you dont need to replace any....
Old Jun 27, 2003 | 03:42 PM
Trial User's Avatar
Default Re: (SantaCruz92Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SantaCruz92Si &raquo;</TD></TR><TR><TD CLASS="quote">adjust your valves.....
valves click..... at least adjust them and while your out it make sure you dont need to replace any....</TD></TR></TABLE>
Old Jun 27, 2003 | 03:49 PM
projectEK9's Avatar
Default Re: (Trial User)
thanks
Old Jun 27, 2003 | 03:58 PM
turbosol's Avatar
Default Re: (projectEK9)
Injectors click too, but they are supposed to. Alot of people mistake them for a problem.
Old Jun 27, 2003 | 04:06 PM
Dancing is Forbidden's Avatar
Default Re: (turbosol)
are you going to adjust them yourself? No offense, but if you cant diagnose the problem, especially with the the valvetrain, dont touch it. You can tighten the valves too tight if you dont know what youre doing and that will cause TROUBLE!
Old Jun 27, 2003 | 04:27 PM
Steve Berman's Avatar
Default Re: (EF9_SiR)
lol. Riiight. Now, to a feasible fix, does the noise persist if you have the clutch pedal in?
Sounds like symptoms of a noisy t.o-bearing to me.
Old Jun 28, 2003 | 12:48 AM
projectEK9's Avatar
hahah...none taken...im gonna have my mechanic take a look at it...im gonna observe and possibly help out...
Old Jun 28, 2003 | 01:02 AM
projectEK9's Avatar
Default Re: (Steve Berman)
the noise goes away when i step on the clutch....now what..heh
Old Jun 28, 2003 | 08:43 AM
Trial User's Avatar
Throw out bearing. The tranny needs to be dropped to replace it. Don't worry about it until you need a new clutch.
Old Jun 28, 2003 | 06:24 PM
This usually occurs when someone installs a new Throwout bearing and fails to lubricate it properly.
Ive had numerous chattering t.b's and they never failed on me.
laboyon
Aug 14, 2008 05:08 PM
Spoonsinglecam
13
Jan 25, 2008 04:22 PM
20ls01
Jun 23, 2007 05:43 PM
VTECcnIT
Nov 7, 2005 01:17 AM
pelotudo
May 3, 2002 08:26 PM
