Alignment Problem
Old Jun 27, 2003 | 02:57 PM
ransack's Avatar
Default Alignment Problem
I went to finally go get my alignment done my on 96 civic. Ive had problem with tire wear in the back passenger side. It would wear excessivly.
I took it to get allignment and they said in the back the toe was off +1.3. So thats whats causing the problem of tire wear. He said that he could only adjust it to +0.6. He couldn't align it anymore.
So my problem is that something is obvisoulsy wrong in that back. Theres no camber kits or anything. Infact, my camber on the rear was
Left: 1.5
Right: 0.4
Which is funny, because both is lowered the same hieght.
I cant figure out what is causing my toe and camber to be out of align. Any help would be great
//Jesse
Old Jun 27, 2003 | 03:02 PM
andrew dc's Avatar
Default Re: Alignment Problem (ransack)
You can probably try to move it some more buy shaving a bit more of the front of the arm (i know confusing). the trailing arm connects to the chasis in about 3 places... compensator arm (rear camber kit goes there)... LCA..... and all the way in front, there is a bolt that you loosen to adjust the toe/camber.. you can remove that bolt and shave some of that off to allow more toe adjustment... (this is all theory)
HTH
STIBungy's Avatar
You actually have positive camber after lowering it? I've taken my car to the alignment shop and baseline all came out negative numbers.
Old Jun 27, 2003 | 03:07 PM
Ivan's Avatar
senior gold member
maybe the trailing arm was messed up before and lowering only messed it up more.
Old Jun 27, 2003 | 03:55 PM
ransack's Avatar
Default Re: (B18CBungy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">You actually have positive camber after lowering it? I've taken my car to the alignment shop and baseline all came out negative numbers.</TD></TR></TABLE>
sorry, its suppose to be negative
So it could possibly be the trail arm bent? If I did a rear GSR disc swap, that replaces it correcT?
Old Jun 27, 2003 | 06:09 PM
andrew dc's Avatar
Default Re: (ransack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack &raquo;</TD></TR><TR><TD CLASS="quote">
So it could possibly be the trail arm bent? If I did a rear GSR disc swap, that replaces it correcT?</TD></TR></TABLE>
you can if it is not bent... im or email me if you need a set.. I am in nor cal too!
Old Jun 27, 2003 | 09:12 PM
ransack's Avatar
Default Re: (andrew ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew ef &raquo;</TD></TR><TR><TD CLASS="quote">
you can if it is not bent... im or email me if you need a set.. I am in nor cal too!</TD></TR></TABLE>
yeah for sure keep in mind
Old Jun 27, 2003 | 09:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
has the car ever been wrecked?
Old Jun 27, 2003 | 11:45 PM
ransack's Avatar
Default Re: Alignment Problem (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">has the car ever been wrecked?</TD></TR></TABLE>
not that I know off
there was no previous major accidents (as far as I know)
but it was owned by a ricer?!?! heh
Old Jun 28, 2003 | 08:05 AM
ransack's Avatar
bump
Old Jun 28, 2003 | 07:19 PM
flex97itr's Avatar
if it helps you at all, when i went to the alignmentshop my drivers side was off and i believe he was only able to get it upto 1.4 or 1.5 or something like that. the reason he said it was off was becuz either my upper control arm or strut was bent. hope this helps
RomesEM1
Suspension & Brakes
Sep 25, 2009 06:37 PM
POWerTuner
Suspension & Brakes
Oct 29, 2007 04:45 PM
lilhatch
Sep 24, 2005 06:40 PM
smikeL
Jan 7, 2005 11:13 PM
