Clock is working, but not working.....
Old Jun 27, 2003 | 11:49 AM
Double_Dk's Avatar
Default Clock is working, but not working.....
OK, so I noticed my clock didn't appear as if it was working. So I pressed the button on the far right, and it showed 1:00. But when I let go, the time went away. Also, every time the car gets shut off, it resets to 1:00. What would cause this to happen? I didn't touch anything in the car!
Old Jun 27, 2003 | 11:56 AM
drunknbass's Avatar
the yellow wire is dead.. the constant power (memory wire)
Old Jun 27, 2003 | 12:04 PM
Double_Dk's Avatar
So, what should I do? Do I have to run a new wire? Or check the connection?
Old Jun 27, 2003 | 12:10 PM
YumVTEC's Avatar
Default Re: (Double_Dk)
fuse?
drunknbass's Avatar
see if the wire fell off. do trouble shooting.. i doubt the whole wire in your harness is dead cause if it was your stereo wouldnt save stations either
Old Jun 27, 2003 | 12:24 PM
95hbMatt's Avatar
Default Re: (drunknbass)
Mine did the same thing..it ended up being a fuse..I believe the under hood one..
Old Jun 27, 2003 | 12:33 PM
Synergy001's Avatar
Default Re: (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt &raquo;</TD></TR><TR><TD CLASS="quote">Mine did the same thing..it ended up being a fuse..I believe the under hood one..</TD></TR></TABLE>
Old Jun 27, 2003 | 12:36 PM
Double_Dk's Avatar
Do you remember which fuse under the hood? Because it isn't clearly labled which is for the clock/radio...
It's in a 92 Civic Si HB
Modified by Double_Dk at 4:53 PM 6/27/2003
Old Jun 27, 2003 | 12:48 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double_Dk &raquo;</TD></TR><TR><TD CLASS="quote">Do you remember which fuse under the hood? Because it isn't clearly labled which is for the clock/radio...
It's in a 92 Civic Si HB</TD></TR></TABLE>
if you are standing in front the car its the bottom left one. 20 amp i believe. there should be a extra 20 and a 10 amp fuse there so you can just use the 20 one.
Old Jun 27, 2003 | 01:19 PM
agent87's Avatar
Default Re: Clock is working, but not working..... (Double_Dk)
Thanks for posting this. My clock has done the exact same thing ever since my car was stolen. They took the radio and I had a feeling it was related...
Old Jun 27, 2003 | 01:27 PM
ninety9ex's Avatar
Mine did the same... check the fuses under your hood... It was either the ecu fuse... or the back-up fuse (7.5A -- RED)... check both!
&lt;&lt;&lt;...
Old Jun 27, 2003 | 01:28 PM
94HybridEX's Avatar
Default Re: Clock is working, but not working..... (ninety3EX)
Red 7.5a fuse under the hood.
Old Jun 27, 2003 | 02:04 PM
Cheivic's Avatar
Default Re: Clock is working, but not working..... (94HybridEX)
It's the backup fuse. Look on the lid and it will show you which one it is.
Old Jun 27, 2003 | 06:24 PM
Double_Dk's Avatar
it was the backup fuse. Good call guys. Thanks for the help!
matchewspoo
May 2, 2010 01:47 PM
sz9182
Audio / Security / Video
Apr 30, 2007 08:27 PM
themackingking
Jul 25, 2004 07:24 AM
HatchBox
13
Aug 7, 2002 10:40 AM
OR-G
May 22, 2002 07:48 AM
