1997 ITR Dyno Results...
Old Jun 27, 2003 | 10:49 AM
SpeedFiend's Avatar
Default 1997 ITR Dyno Results...
Here's my dyno graph from June 26, 2003. We were comparing the benefits of the Hondata tuning vs. an APEX-i VAFC. Note that these were done on a Dynojet and the temperature difference was almost 25 degrees (100F Hondata vs. 74F VAFC).
The Setup
- Full port and polish (head and throttle body)
- Fully balanced bottom end
- Knife-edge crank
- High compression (12.1:1) Wiseco forged pistons and wrist pins
Mugen Valve Springs
Mugen 4-1 Header
Mugen Twin Loop Exhaust
Mugen Thermostat
Spoon Radiator Hose set
AEM Cold air intake
AEM Pulleys
AEM Cam gear
Transmission
JDM 4.785 Final Drive Gear set
Mugen LSD
Exedy Hyper Single Clutch/Flywheel
Engine/Fuel/Ignition Management
Hondata s200
RC Engineering 310cc injectors
STR Competition fuel rail
Fuel pressure regulator
MSD Ignition amplifier
Crane PS92 coil
Old Jun 27, 2003 | 10:51 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: 1997 ITR Dyno Results... (Michael)
I`d start with a better header and exhaust. Jo0 need 2.5" all the way back.
edit: not too shabby for stocker cams
Old Jun 27, 2003 | 10:52 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 27, 2003 | 10:56 AM
SpeedFiend's Avatar
Default Re: 1997 ITR Dyno Results... (.RJ)
I know that there are plenty of other setups that would put down more power...but I'm just another case of JDM whoreism at its worst.
Old Jun 27, 2003 | 11:13 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael &raquo;</TD></TR><TR><TD CLASS="quote"> We were comparing the benefits of the Hondata tuning vs. an APEX-i VAFC</TD></TR></TABLE>
I don't see any difference. who tuned the hondata?
Old Jun 27, 2003 | 11:19 AM
Art Vandeleigh's Avatar
which is which? red is vafc and blue hondata? or other way around...
Old Jun 27, 2003 | 11:36 AM
SpeedFiend's Avatar
Default Re: 1997 ITR Dyno Results... (Art Vandeleigh)
Sorry guys...
Blue is the Hondata and Red is the VAFC
Not much of a difference? I think its a pretty big difference considering that there is a 25 degree increase in temperature from the Blue to Red graph.
Old Jun 27, 2003 | 11:45 AM
mafay2's Avatar
New User
IF they are both SAE corrected number, then it should not make a difference if it is hotter.
Old Jun 27, 2003 | 11:50 AM
fredtoast's Avatar
I thought SAE adjustment took temperature into account. Is this correct?
Old Jun 27, 2003 | 11:52 AM
for the TQ numbers i cant even tell which is blue and which is red... is it just me??
but i really dont think they tuned it right...or maybe thats all there is to be had. if the later case is true then i think the hondata was a waste of money in all honesty. your TQ numbers are almost identical. and the only place where you really picked up better results were from 7.5 to 8.5 on the hp curve....
maybe try going to another dyno tuner, where are you located?
Old Jun 27, 2003 | 12:12 PM
SpeedFiend's Avatar
Well, we are not looking at a stock vs. Hondata comparison here. It is a finely tuned VAFC dyno graph compared to the Hondata. The VAFC was tuned via MoTeC air/fuel meter.
Old Jun 27, 2003 | 12:13 PM
Dave-ROR's Avatar
Default Re: 1997 ITR Dyno Results... (mafay2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafay2 &raquo;</TD></TR><TR><TD CLASS="quote">IF they are both SAE corrected number, then it should not make a difference if it is hotter.</TD></TR></TABLE>
Correct. And the graph says SAE corrected. Possibly the excuse the tuner used
Old Jun 27, 2003 | 12:36 PM
SpeedFiend's Avatar
Default Re: 1997 ITR Dyno Results... (FizzleDaKlown)
Of course there are many Hondata tuners out there that would bring out more power, but I am pretty satisfied to see 193 whp out of the stock cams.
Old Jun 27, 2003 | 12:58 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael &raquo;</TD></TR><TR><TD CLASS="quote">Of course there are many Hondata tuners out there that would bring out more power, but I am pretty satisfied to see 193 whp out of the stock cams. </TD></TR></TABLE>
I made no comment about the power you are putting down, but that is not much difference. There should be more.
Hell George puts down 191 (and it's not tuned for peak, likely of close to 200 or more) with less mods than you have.
Newer motor though, but even with the slight cam difference I don't think it's that big of a difference imo.
If you have the chance, get the car to a more experienced tuner with your application.. especially when you get Toda C's. Just take it to Steve (sGT) or Yack
Old Jun 27, 2003 | 01:09 PM
98R-1144's Avatar
i think trying a new tuner would probably net you better gains? the hondata looks pretty jagged compared to the vafc.. so i'm sure betting adjustments can be made
Old Jun 27, 2003 | 04:04 PM
Warren's Avatar
Wrong-Way Wang
Ditch the Mugen thermostat.
FYI - Mugen valvesprings are just ITR valvesprings.
With 12:1 comp, and Hondata, you should be near 200.
Warren
Old Jun 27, 2003 | 04:05 PM
MackSpeed-616's Avatar
Default Re: 1997 ITR Dyno Results... (Warren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">
Warren</TD></TR></TABLE>
true but with 86mm bore and jun 3s he'll be near 300
LOL
Old Jun 27, 2003 | 07:27 PM
SuperTwinz's Avatar
https://honda-tech.com/zerothread?id=150679
Old Jun 27, 2003 | 07:38 PM
canuck-mx6's Avatar
It does, SAE corrected cannot factor in the effect that heat soak has on the motor.
Old Jun 28, 2003 | 06:50 AM
Dave-ROR's Avatar
Default Re: 1997 ITR Dyno Results... (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">
It does, SAE corrected cannot factor in the effect that heat soak has on the motor. </TD></TR></TABLE>
True, but we also have no idea what conditions the pulls were made under. The VAFC pull could have been the 5th, or 6th, or 9th pull of the day. The Hondata is pull 10, made almost a year later. How can we say the motor was more heat soaked for that run just based on ambiant temp?
Old Jun 28, 2003 | 06:52 AM
SpeedFiend's Avatar
Sorry...the pull is not #10. It was #4.
Old Jun 28, 2003 | 06:59 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael &raquo;</TD></TR><TR><TD CLASS="quote">Sorry...the pull is not #10. It was #4.</TD></TR></TABLE>
they are listed as DYNORUN.009 and DYNORUN.010.. did the guy just pick numbers at random?
Old Jun 28, 2003 | 10:53 AM
DC2R-PoweR's Avatar
good job man
u can do better
Old Jun 28, 2003 | 12:34 PM
hulkhb's Avatar
Default Re: 1997 ITR Dyno Results... (DC2R-PoweR)
as stated by others.....
cams and header/exhaust will make alot more gains.
nice though
Old Jun 28, 2003 | 12:57 PM
Broken Gearbox's Avatar
Default Re: 1997 ITR Dyno Results... (hulkhb)
not bad numbers...but like everyones saying get some better cams and a better exhaust set-up and you'll see more gains
