Quick axle question for B16 swap .....
Old Jul 26, 2001 | 04:36 AM
TypeR0207's Avatar
Default Quick axle question for B16 swap .....
Into a 4g Civic (EF).
If I just get '90-'91 Teg axles, then all I have to do is get the same year Intermediate shaft, and I'll have no axle worries, right?
What did you guys do??
Old Jul 26, 2001 | 04:19 PM
Red Civic T's Avatar
New User
Default Re: Quick axle question for B16 swap ..... (TypeR0207)
NO!!!!!Depends on which tranny....YOu can check Erick Bauer's site or else I think HASPort.com has 411 on which axles and int. shaft....
Old Jul 27, 2001 | 03:33 AM
TypeR0207's Avatar
Default Re: Quick axle question for B16 swap ..... (Red Civic T)
I did, but I beleive that the HASport site has the opposite, they tell you which axle to use based on which intermediate shaft you already have.
I remember someone else saying on the board that the way to clear up the intermediate shaft question is to just use the same one that you have the axles for.
Old Jul 27, 2001 | 03:58 AM
New User
My read on it was that if you have a Y1 tranny you use an 86-89 int shaft, and for S1/J1 tranny 90-93 int shaft (from teg). It should then tell you which axles to use with that....Hopefully you have S1 and then you just use 90-93 hookup for both.
Don't be like me and forget to tell wrecking yard that you need for MANUAL, not AUTOMATIC which look beefier but are like o.5 inch too long....
JustAnotherRex
Jan 9, 2009 05:29 PM
nexgen91
Mar 26, 2006 08:44 AM
crexer
27
Dec 22, 2004 10:39 PM
type Gendy
13
Feb 3, 2003 10:51 PM
TypeR0207
Jul 28, 2001 02:03 PM
