how to see if your CEL light is dead
Old Jun 27, 2003 | 05:22 AM
Spudddy's Avatar
Default how to see if your CEL light is dead
Alright guys I have reason to believe that my light for my CEL died. any tests I can do to test this? Right now my second 02 sensor is unplugged.. the one in the cat. should this throw a cel? Thanks
Old Jun 27, 2003 | 07:29 AM
JimBlake's Avatar
Default Re: how to see if your CEL light is dead (Spudddy)
Well, if you turn the key to 'on' without starting the engine, it lights up everything as a bulb-check. You ought to do that once in a while, so you can tell if any of the bulbs are burned out.
I guess it should light up with the 2nd sensor unplugged...
Old Jun 27, 2003 | 08:53 AM
Blaze45's Avatar
Brrraaaap!
Default Re: how to see if your CEL light is dead (JimBlake)
Bump cause mine wont turn on eathier for the bulb check. No spark.
Blaze
Old Jun 29, 2003 | 04:20 PM
JimBlake's Avatar
Default Re: how to see if your CEL light is dead (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Bump cause mine wont turn on eathier for the bulb check.</TD></TR></TABLE>
Well then your bulb must be burned out. But that won't fix your spark.
Old Jun 29, 2003 | 06:00 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Bump cause mine wont turn on eathier for the bulb check. No spark.
Check your fuses.
b16a3delsol
17
Aug 13, 2007 03:49 AM
BseriesHeaven
May 22, 2007 08:01 PM
stealth89hatch
Aug 15, 2005 04:48 PM
shreddinryguy
Jun 27, 2005 05:23 AM
B_CRUZ!
12
Aug 10, 2003 04:05 PM
