does it matter how many bolts the cam gears have?
Old Jun 27, 2003 | 03:33 AM
90teg's Avatar
Default does it matter how many bolts the cam gears have?
just noticed that aem cam gears have 3 bolts while dc sports, str, skunk2 have 5 bolts. does it matter how many bolts they have? are any set of cams better or more reliable then the other?
Old Jun 27, 2003 | 04:54 AM
StyleTEG's Avatar
Default Re: does it matter how many bolts the cam gears have? (90teg)
More bolts probably have better resistance to slipping.
Old Jun 27, 2003 | 05:05 AM
conesmasher's Avatar
Default Re: does it matter how many bolts the cam gears have? (StyleTEG)
If the bolts are torqued to the correct specs, they should have no resonable chance of slipping. I have only ever heard heresey about AEM cam gear slippage.
It's kinda like doubling up on condoms, no real extra protection, but it makes you feel better.
And they use the same cam gears on Papadakis race car, that thing makes more power than you could even imagine, feel safe yet. If not double up.
Old Jun 27, 2003 | 05:25 AM
Charlie Moua's Avatar
Default Re: does it matter how many bolts the cam gears have? (snoballgsr)
https://honda-tech.com/zerothread?id=526559
Hope that helps
Old Jun 27, 2003 | 06:22 AM
90teg's Avatar
Default Re: does it matter how many bolts the cam gears have? (Charlie Moua)
yeah that helped thanks...
Old Jun 27, 2003 | 06:48 AM
StyleTEG's Avatar
If you are still worried you could always use some low strength loctite to ensure they don't move.
urnotfast
Sep 19, 2007 10:39 PM
JDM_EK4_Coupe
Apr 30, 2007 12:19 PM
boost hep
Jan 31, 2007 04:31 PM
respectblades
Sep 7, 2003 12:13 PM
cracker099
Apr 23, 2003 09:58 AM
