messed up radiator install help! DOH!
Old Jun 26, 2003 | 08:50 PM
Tad's Avatar
Tad
Default messed up radiator install help! DOH!
heh,
ok so my friends radiator died(rock hit it or some ****).
so we get a new radiator off ebay.
and installed it last night.
pretty easy install..
but we messed up somewhere..
basically.. the bitch is overheating! DOH!!!
We basically just followed the instructions in his honda owners manual for the coolant system to refill it.
and it looks like everything alright.
but if we drive it around for a while.. the temp. will slowly creep up.
SOOO, i'm thinking there was something more we needed to do.
like maybe flush the entire coolant system?
My question, is that do you guys think it'll be alright and work normally if we went ahead and flushed the system following instructions in a better manual(maybe hanes.. or if I can find the real mechanics manual online in pdf format).
what do you think?
thanks.
P.S. he has a 99 civic dx
Old Jun 26, 2003 | 08:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: messed up radiator install help! DOH! (Tad)
let it run with the cap off, heat on. it may be air bound and have to burp. hope that helps.
Old Jun 26, 2003 | 09:08 PM
degooser's Avatar
make sure there is enough coolant in the radiator..
check it when its cool...
Old Jun 26, 2003 | 09:25 PM
aw1234dude's Avatar
Default Re: messed up radiator install help! DOH! (degooser)
Yeah theres probably and air bubble in the line. I usually start the car and let it idle while I go over to the radiator, and uncap it. I then squeeze the big upper radiator hose repeatedly. When you squeeze the hose, somewhat fast like, youll notice that air bubbles will pop up. Just keep filling the radiator to the top and squeezing. I usually do this for a good 5 to 10 minutes just to make sure theres no more air bubbles.
Old Jun 26, 2003 | 10:41 PM
Tad's Avatar
Tad
Default Re: messed up radiator install help! DOH! (aw1234dude)
ok I told him to try that!
hopefully it'll work.
but so you dont think it needs to be flushed?
Old Jun 27, 2003 | 01:29 AM
aw1234dude's Avatar
ehh as long as the majority of the coolant is new it should be good.
Old Jun 27, 2003 | 01:45 AM
Kamin's Avatar
Bleed the coolant. i will put money on that being the problem.
Old Jun 27, 2003 | 11:36 AM
Tad's Avatar
Tad
wuts bleeding the coolant do?
Old Jun 27, 2003 | 12:16 PM
Mr. Badwrench
Default Re: (Tad)
basically it is what you told him to do. get the air pocket out.
Old Jun 27, 2003 | 04:16 PM
built562's Avatar
Default Re: (boostedcivicsir)
stupid thought but did you check to see if there was anything stuck inside the hose outlets, companies will stick something in there to prevent things from getting inside the radiator during shipping. but other than that you should have flushed and bled the system.
Old Jun 27, 2003 | 04:36 PM
2.0L EK's Avatar
Default Re: (akumaracer)
turn the heater vent inside the car to hot, but dont turn the fan on. Start up the car with the rad. cap off. let the car warm up and let the fan turn on. Keep squeezing the upper rad. hose to see if the thermostat opened. it should stay cold for a while 4-6 mins, but then heat up very quickly. Good Luck
[edit] turning the heater vent to hot opens the heater core under your dash. Chances are there is some air stuck in there. [edit]
Old Jun 27, 2003 | 06:07 PM
jaxle's Avatar
uh there is a air bleed bolt that u loosen when filling coolant. get a haynes manual if u want to know where it is and what it looks like.
Old Jun 27, 2003 | 06:11 PM
andrew dc's Avatar
Default Re: (jaxle)
i let the car cycle 3 times with the cap off... (ie let the fan kick on 3 times) refilling it every time it goes low...
Dm914
Jun 25, 2015 05:31 PM
preludepower01
Jul 3, 2010 09:10 AM
halo2k7
17
Jul 23, 2008 09:57 PM
acmoc
Apr 2, 2008 03:03 PM
XxRoCkMaNxNEOxX
Oct 21, 2004 10:31 PM
