Idle problem with EMS .. searching for a map b18c1 w/ 760cc
Old Jun 26, 2003 | 04:55 PM
meanteg's Avatar
New User
Default Idle problem with EMS .. searching for a map b18c1 w/ 760cc
obd2 b18c1
9:1 cr
t3/60-1 turbo,
with the stock ecu, injectors and MAP, the motor idles fine
but
when I install the EMS 1020, GM 3 bar MAP, 760cc MSD w/ resistor box, the car cannot idle at all. ( way too rich )
I 'm running a modified 440cc map, cause I didn't find a 760cc map on the EMS forum.
Howevwer, I know there is someone else that has a similar setup to mine. What have you done to make it idle well ?
Maybe someone would share his map with me. Thanks.
Old Jun 26, 2003 | 04:56 PM
meanteg's Avatar
New User
Default Re: Idle problem with EMS .. searching for a map b18c1 w/ 760cc (meanteg)
P.S.: YES, I did reduce the duty cycle a LOT. It hasn't helped.
jonman27
Oct 22, 2010 01:25 PM
brutekiller787
Mar 12, 2010 06:12 PM
VTC_CiViC
Apr 12, 2004 06:00 AM
