brake fluid leak
Old Jun 26, 2003 | 04:52 PM
deviant1's Avatar
Default brake fluid leak
today i noticed brake fluid dripping out of the brake master cylinder cap and down the wires where it drips onto the frame. i changed my rotors and pads 2 days ago and did not take the cap off the MC when i pushed the piston back in. it looks as tho the fluid level in the resevoir has not gone down at all. its still at the top. is this just extra fluid pushed from the calipers into the resevoir when i pushed the pistons back in with the cap still on? or is this normal at all?
Old Jun 26, 2003 | 07:50 PM
deviant1's Avatar
Default Re: brake fluid leak (deviant1)
Old Jun 26, 2003 | 08:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
when you press the pistons in, the fluid returns to the master cylinder. you need to take a turkey baster, clean of course, and remove the excess to the max line. if you dont do this, when brake fluid gets hot it will expand and apply your brakes a little. this will cause them to wear pre-maturely. i know it sounds weird but it is true.
mtacket45
Aug 3, 2014 01:18 AM
Andyxramirez
Mar 11, 2013 05:56 PM
92integraVTECgsr
Jun 7, 2006 02:57 PM
Flux
Jul 14, 2002 09:57 PM
