99 Accord Remote Wire?
Old Jun 26, 2003 | 04:28 PM
hatch808's Avatar
Default 99 Accord Remote Wire?
What color is the remote wire from the stock stereo harness? can you hook up an amp if there is no audio connectors on the stock deck? if so what do i do? Thanks in advance!
Old Jun 26, 2003 | 06:30 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: 99 Accord Remote Wire? (hatch808)
no audio connectors as in no rca outputs? no, you cannot..well..not in any practical kind of way. I guess you could wire some rca connectors onto the end of a speaker wire and connect that to the amp...but it's gonna sound like **** so just buy a new head unit with rca outputs. As for the remote wires that depends on your model so look it up on the net. mine was solid light blue...i think.
Old Jun 26, 2003 | 06:54 PM
-RedneckDave-'s Avatar
Working
Default Re: 99 Accord Remote Wire? (fluxion)
Nope you are wrong fluxion, you can install an amp with a factory head unit and it is very easy. Go to a stereo shop and ask for a RCA adapter and you will get what you need then to run a remote wire you do not have to use the one from the radio. You can use any lead that turns on with the accessory switch, for example you can use the wire that goes to the cigarette lighter and that will work. If you have any install questions do not be afriad to ask just PM me. However this is in the wrong forum and i suggest that you read the TOS or Terms of Service and here is the link. https://honda-tech.com/zerothread?id=406053
Old Jun 27, 2003 | 02:51 AM
hatch808's Avatar
i relaized this was posted in the wrong forum after my wife posted it, thanks for the input though ill go buy one today.
kcivicboi
Audio / Security / Video
Feb 23, 2006 11:26 AM
boostincoupe
Oct 6, 2005 05:19 PM
tdcdodger
Mar 29, 2005 02:04 PM
another_crx
Dec 28, 2003 06:39 AM
SIMATIC
Jul 2, 2003 07:41 AM
