question about piston rings
Old Jun 26, 2003 | 12:40 PM
Nextelbuddy's Avatar
Default question about piston rings
i have just aquired another b18c1 block but this block is complete with everything only problem is that the car it came out of it was smoking bad especialyl when vtec kicked in. well i figured the im going to need new pistons rings. but the thing is how do i tell if the cylinder walls need to be HONED? will it be something that i cant visually see? or is it something i can actually look at and tell?
for example, sya i go look at it right now and the walls look smooth does that mean im good to go , or wil the damage be to the point where i can not see with a naked eye? any advice please
also how much does it cost to get the cylinder walls honed?
Old Jun 26, 2003 | 12:58 PM
-Trinitron-'s Avatar
Default Re: question about piston rings (nextelbuddy)
You should be able to see the hatchings in the cylinder walls...if they are completely smooth they need to be honed. I would hone anyway for good measure. It is better to be safe than pregnant...i mean, sorry.
Old Jun 26, 2003 | 01:11 PM
Default Re: question about piston rings (SlowBlueSi)
wait im confused. what do i look for on the cylinder walls to see if needs to be honed? what is good? are smooth walls good? or are smooth walls bad? which is which lol
Old Jun 26, 2003 | 01:27 PM
b19coupe's Avatar
Inspect the bores, if you see any gouges or scratches, run your fingernail across them. If you can feel it with your fingernail, you need to bore the motor. If not, you might be o.k. with a hone job and new rings. Personally, I would not run a block that has not been checked by a good machine shop for a true deck and out of round cylinders.
Old Jun 26, 2003 | 01:34 PM
3rdGteg's Avatar
Default Re: question about piston rings (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I would not run a block that has not been checked by a good machine shop for a true deck and out of round cylinders.</TD></TR></TABLE>I would definitely measure the bores for taper, out-of-round, etc. before deciding whether to bore or just hone the cylinders; but if you just want to take a costly chance at just putting it all back together as is w/o measuring, at least get them honed.
Old Jun 26, 2003 | 01:40 PM
Default Re: question about piston rings (3rdGteg)
does anyone know what pistons rings i use for the 1st gen b16 PR3 pistons??
Old Jun 26, 2003 | 02:29 PM
3rdGteg's Avatar
any b-series rings i believe; but i'm definitely sure the b16 rings from a del sol or 99-00 Si or even from an LS motor will work.
Old Jun 26, 2003 | 02:30 PM
b19coupe's Avatar
13011-PR3-003 (Teikoku), or 13011-PR3-004 (Riken), both standard bore.
Or: 13021-PR3-004-0.25mm over.(Riken).
blackeg
Dec 12, 2013 01:37 PM
Stoich EG2
Jul 18, 2007 04:29 AM
Rosko
12
Mar 17, 2007 04:09 PM
jennsGSR
Aug 17, 2006 06:12 PM
wm5holla
Jul 19, 2003 08:59 PM
