whats needed to install hondata?
Old Jun 26, 2003 | 12:15 PM
all_mota's Avatar
Default whats needed to install hondata?
sorry for the newbie question, i read all the FAQ's and what not on the hondata.com website and i thought i had everything to install my hondata s200.
anyways, i have a 96 civic coupe, ITR engine, hondata s200, and a Kenji p28 ecu with an obd1 conversion harness, and was wondering what else i needed to install the hondata s200? or is that all i need? my mechanic said that there are like 2 wires that are needed to connect the hondata to the ecu but i did not see anything about that when reading about the hondata on the website.
thank you
Old Jun 26, 2003 | 12:43 PM
RTW DC2R's Avatar
Default Re: whats needed to install hondata? (all_mota)
Im not running hondata, but it sounds like you have what you need. I would think the s200 would have come with any wires needed to connect to the ECU.
Old Jun 26, 2003 | 12:47 PM
all_mota's Avatar
yeah, the s200 comes with some things, but i think he was talking about the ECU not being ready for to accept the Hondata unit or something.
sgT? anyone else with hondata? what all did you do to intall it?
Old Jun 26, 2003 | 12:50 PM
Hybrid ctr's Avatar
Default Re: (all_mota)
IM sgT
Old Jun 26, 2003 | 12:56 PM
Austin's Avatar
You need to read the Install brochure in the download section of the Hondata.com website, it tells you what needs to be done to the ecu to prepare it for Hondata S200.
Austin
Old Jun 26, 2003 | 01:18 PM
AK94GSR's Avatar
Default Re: (Austin)
doesn't some sort of socket need to be put into the ecu so u can place the chips into it.
Old Jun 26, 2003 | 01:50 PM
Austin's Avatar
Default Re: (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR &raquo;</TD></TR><TR><TD CLASS="quote">doesn't some sort of socket need to be put into the ecu so u can place the chips into it.</TD></TR></TABLE>
Yes...there are a few things that need to be soldered into the ECU to accept the Hondata setup, soldering of a socket, some resistors, a chip, and a 4 prong plug for communication with the Hondata box.
Old Jun 27, 2003 | 12:16 PM
sgT's Avatar
sgT
your ecu will need the comm port installed intoit. its the small 4 pin white plug.
greddy2244
Engine Management and Tuning
May 6, 2012 09:01 AM
NoVtecLs
Oct 6, 2004 05:54 PM
aziz93
Aug 16, 2004 08:29 AM
speedyonez
Oct 20, 2003 06:49 PM
