3" DP for Greddy Turbo
Old Jun 26, 2003 | 08:00 AM
DBallz's Avatar
Default 3" DP for Greddy Turbo
Now it has been said that with the greddy turbo for the Si if you use a 3” downpipe that boost spike will occur. But what if you use the 3”dp with a 2.5” catback exhaust. I want to put the 3”dp on my car before I go to get it tuned. I’m going to be using the hondata to tune the car when I get back from Miami next month. I’m just looking to tune 15psi max for now. Does anyone know if doing a 3”dp with 2.5 catback will be a problem or will I be okay. Does anyone with a greddy turbo have a 3”dp? PM me.
Thanks.
Old Jun 26, 2003 | 08:50 AM
evoeone's Avatar
Default Re: 3" DP for Greddy Turbo (DBallz)
3" rules damian, come ot me and ill make you a dp.... mayeb it spikes cause you have an internal wastegate
Old Jun 26, 2003 | 09:19 AM
DBallz's Avatar
Default Re: 3" DP for Greddy Turbo (evoeone)
Well I heard you get spiking when you run full 3" turbo back but I don't know I might have you make a 2.5"dp
Old Jun 26, 2003 | 09:38 AM
VTC_CiViC's Avatar
The internal wastegate in these Mitsu turbo's doesn't like to hold boost very well, especially with larger exahusts. I know I had a hell of a time spiking all over the place with a 2.5" DP and 3" catback on my GReddy kit.
Old Jun 26, 2003 | 09:45 AM
gritsak's Avatar
Default Re: 3" DP for Greddy Turbo (VTC_CiViC)
on other mitsu turbos on dsms (i.e. 16g's, big 16's, ect.) they have the same problems...if you plan on keeping the turbo you could prolly send it out somewhere and have them port the wastegate opening out and install a larger flapper. that usually takes care of the problem
Old Jun 26, 2003 | 12:26 PM
DBallz's Avatar
Default Re: 3" DP for Greddy Turbo (gritsak)
Well I'm planning on saving that for when I send it out to Forced Performance they said they can upgrade me to a FP green turbo with a larger internal wastegate. But I will just run a 2.5DP with my N1 Cat back 15 psi should be okay.
Old Jun 26, 2003 | 01:07 PM
SupaTeg's Avatar
Where do you guys get your information from? You can upgrade to a 3" and you won't have boost spike. Call GReddy and they will tell you themselves
Nisif
Jun 26, 2013 11:20 AM
xander1100
Jan 27, 2009 06:24 AM
Liquidgsr
Aug 11, 2006 11:09 PM
untitled
Nov 3, 2003 07:19 PM
