Deltagate Hookup/Vaccum Lines
I was wondering if any of you knew what hooked up to the brass fitting on the side of the deltagate wastegate. And what hooks up to the fitting on the compressor side of the turbo. The car is builing too much boost. Thanks guys!
94 gsr-T sedan
94 gsr-T sedan
the side port on the deltagate, should go to the port on the compressor side of the turbo... (easiest)
THEN the top port of the deltagate should be open unless you are running a elec. boost controller.
you are building too much boost because the wastegate isnt hooked up...
DIRep972
Sep 11, 2004 01:26 PM
_Endless_
Sep 23, 2002 10:00 PM
