EMERGENCY HELP!!! Honda dealer shop...
Old Jun 26, 2003 | 06:40 AM
kay_animation's Avatar
Default EMERGENCY HELP!!! Honda dealer shop...
My mom has a honda prelude that I'm getting, but long story short, it was making this grinding/creaking sound comming from the engine so she put it in the honda shop. Well they said it was the Timing belt tensioner and that it was rusting and had to be replaced. They also said they were going to replace the timing belt and water pump too since they had the engine apart already. Well, they want $1200.00 to do the work and parts. Is that diagnostic right? Is that price right? Is that repair needed? What would a DIY mechanic do??? Please help asap. Its in the shop right now and their just waiting on a part before they start on the engine.
Old Jun 26, 2003 | 06:44 AM
symba's Avatar
Default Re: EMERGENCY HELP!!! Honda dealer shop... (kay_animation)
Anytime you do something through the dealer, you're going to get an inflated price. I had my timing belt, accessory belt, and water pump changed and it came to $800. That was at a local performance shop. Don't know if that helps you, but I would maybe look around for any local performance shops in your area...If you have the time...see if anyone here knows of any good places in your area
Old Jun 26, 2003 | 06:50 AM
Basicly, the water pump is fine. So is the timing belt. They just reccomended that we change it cause the tensioner is getting changed. So basicly, I'm asking how much it should cost, parts and labor, to change the timing belt tensioner alone.
Old Jun 26, 2003 | 08:59 AM
goalieman81's Avatar
If you are mechanically inclined at all I would just go for it. Pick a good weekend and tear in to it! Unless you have had the timing belt and water pump done recently I would reccomend going ahead and replacing them. If you dont feel comfortable DIY then I would definitley find another shop....anywhere BUT the dealer. THE DREADED "D" WORD!!! lol
Old Jun 26, 2003 | 09:11 AM
bgod's Avatar
Default Re: (goalieman81)
they should harldy be charging any extra labor to replace the tensioner. if they already have the covers off, belt removed it should be much more over just hte cost of the tensioner which isn't much.
a typical waterpump/timing belt job at even a honda dealer around the ny/nj area runs around $475-$600. can't see it being much more in your area.
so another $600 is a little high. however, find out how much they are charging you just to diagnose the problem which would ad to the costs.
Old Jun 26, 2003 | 01:03 PM
del_parker's Avatar
damn, that's a rip-off. the extra labor is pretty much BS since it would only take about 10 minutes to swap out the tensioners once everything is apart.
a DIY would DIY, so the total cost for the tensioner, timing belt, and water pump would be less than $300, and i would swap the h22 auto tensioner for the h23 manual tensioner.
SequoiaHonda
22
Mar 20, 2015 09:39 PM
tony_2018
Jul 20, 2014 02:59 PM
pone2332
Jan 3, 2008 11:06 AM
dctoast
Dec 16, 2004 05:35 PM
Bobby
Nov 25, 2002 08:42 AM
